🎉Community Raffle - Win $25
Join and Win
Couldn't save process after upgrading server to 7.501
User: "Samhk"
New Altair Community Member
Updated by Jocelyn
After upgrading RM Server and Studio to 7.5.001, I could not save the same process like it did on the previous version. Please help.
  • Exception: java.io.IOException
  • Message: Cannot store process at //RapidMiner_Server/home/admin/ForScheduling/CustomerProfiling_v2/405_Update_Full_Profile: Cannot connect to RapidMiner Server repository 'com.sun.xml.internal.ws.fault.ServerSOAPFaultException: Client received SOAP Fault from server: javax.persistence.PersistenceException: org.hibernate.exception.SQLGrammarException: could not execute statement Please see the server log to find more detail regarding exact cause of the failure.'.
  • Stack trace:
  • com.rapidminer.RepositoryProcessLocation.store(RepositoryProcessLocation.java:161)
  • com.rapidminer.Process.save(Process.java:1436)
  • com.rapidminer.gui.actions.SaveAction$1.run(SaveAction.java:124)
  • com.rapidminer.gui.tools.ProgressThread$3.run(ProgressThread.java:550)
  • java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  • java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  • java.lang.Thread.run(Thread.java:745)
  • Cause
  • Exception: com.rapidminer.repository.RepositoryException
  • Message: Cannot connect to RapidMiner Server repository 'com.sun.xml.internal.ws.fault.ServerSOAPFaultException: Client received SOAP Fault from server: javax.persistence.PersistenceException: org.hibernate.exception.SQLGrammarException: could not execute statement Please see the server log to find more detail regarding exact cause of the failure.'.
  • Stack trace:
  • com.rapidminer.extension.remote.repository.remote.DefaultRemoteRepository.handleExceptionsForService(DefaultRemoteRepository.java:835)
  • com.rapidminer.extension.remote.repository.remote.RepositoryServiceFacade.handleException(RepositoryServiceFacade.java:64)
  • com.rapidminer.extension.remote.repository.remote.RepositoryServiceFacade.storeProcess(RepositoryServiceFacade.java:251)
  • com.rapidminer.extension.remote.repository.remote.DefaultRemoteProcessEntry.storeXML(DefaultRemoteProcessEntry.java:76)
  • com.rapidminer.RepositoryProcessLocation.store(RepositoryProcessLocation.java:151)
