🎉Community Raffle - Win $25
Join and Win
RM Server putting all tables in the Postgres public schema
User: "rachel_lomasky"
New Altair Community Member
Updated by Jocelyn
I got RM talking to Postgres, but instead of putting its tables in the schema I indicated, they are all in the public schema.  Is there a way around this?
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE properties SYSTEM "http://java.sun.com/dtd/properties.dtd">
<properties>
<entry key="db_driver_path">data/jdbc/postgresql-9.3-1101-jdbc4.jar</entry>
<entry key="db_driver_path_is_relative">true</entry>
<entry key="db_driverclass">org.postgresql.Driver</entry>
<entry key="db_password">mypass</entry>
<entry key="db_port">5432</entry>
<entry key="db_schema">rapidminer</entry>
<entry key="db_system">PostgreSQL</entry>
<entry key="db_url">mymachine.cy5mwbb5zo5d.us-east-1.rds.amazonaws.com</entry>
<entry key="db_user">myuser</entry>
<entry key="server_service_id_overwrite">null</entry>
<entry key="eula_accepted">true</entry>
<entry key="server_port">8080</entry>
<entry key="mail_password"/>
<entry key="installation_directory">/opt/rapidminer</entry>
<entry key="license_key">mykey</entry>
<entry key="server_host">127.0.0.1</entry>
<entry key="server_register_as_service">false</entry>
<entry key="mail_port">25</entry>
<entry key="server_service_linux_variant">SUSE</entry>
<entry key="mail_sender"/>
<entry key="memory_max">2048</entry>
<entry key="radoop_proxy_port">1081</entry>
<entry key="mail_url"/>
<entry key="server_service_name">RapidMiner_Server_7_5_1</entry>
<entry key="java_home"/>
<entry key="server_service_id">RMS751SVC</entry>
<entry key="server_host_bind_only">false</entry>
<entry key="radoop_proxy_enable">false</entry>
<entry key="mail_user"/>
</properties>
1 - 4 of 41
    User: "Thomas_Ott"
    @BalazsBarany any pointers for @rachel_lomasky?
    OP
    Accepted Answer
    The db_url is:
    <entry key="db_url">my_database.1.2.3.4/my_schema</entry>, where 1.2.3.4 is the IP of my database machine.
    User: "BalazsBaranyRM"
    Just to clarify:
    Some other databases have a different meaning of schema than PostgreSQL.
    In PostgreSQL, there's a "database" that can contain schemas. The default schema is "public". You can create schemas with "CREATE SCHEMA myschema" and deselect the "use default schema" checkbox in RapidMiner to refer your schema.
    This works well, I use RapidMiner heavily with PostgreSQL.
    OP
    That's for the RM configuration tables, not the data that I am working with?
