Twitter connection problem
Hi...trying to build a twitter connection on RM Server 7.4 and I keep getting an error. Here's what I did:
- Added a Twitter connection on my server from the RM Studio "Add connection" interface.
- Tested with success.
- Added "admin" as user
- Save all changes.
- Logged into RM Server and went to Connections. The token is already pasted into the access_token window. When I click "Test Connection Parameters", I get "Test failed: Twitter API access token has incorrect format"
- Tried deleting the token and then literally copying and pasting the token manually from Studio to Server - same result.
Help?
Thanks.
Scott
Hi Scott,
my bad
I did not create a Twitter connection in a while. Do you still have the token somewhere around? Otherwise create this Twitter connection on and for your local machine and copy the token then into the Web interface, hit Submit and test the connection.
Best,
Edin
Hi Scott,
sorry for the delay - We had a public holiday in Germany
I tried to reproduce the problem and it worked. Thus I realized that you need to hit Submit before you can Test the connection - otherwise it failed for me as well.
Are you running other extensions which work connecting with access tokens, so we can therefore narrow it down to the Twitter connection?
Best,
Edin
No problem, Edin. We're on holiday this weekend too.
I tried it all again from scratch just now and RM Server confirmed that it made a connection with Twitter (green "Connection successful") in the Connections window. But running a process with Twitter and that connection still fails. Here's the log file:
18:36:17,008 INFO [com.rapidminer.Process.16] (scheduledprocess_1495823776993) Process //_LOCAL/projects/ExchangeRates/Twitter import starts
18:36:17,011 SEVERE [com.rapidminer.Process.16] (scheduledprocess_1495823776993) Process failed: com.rapidminer.operator.UserError: Error on connecting to Twitter API.: com.rapidminer.operator.UserError: Error on connecting to Twitter API.
at com.rapidminer.operator.web.services.twitter.AbstractTwitterOperator.getTwitter(AbstractTwitterOperator.java:99)
at com.rapidminer.operator.web.services.twitter.AbstractStatusTwitterOperator.createExampleSet(AbstractStatusTwitterOperator.java:139)
at com.rapidminer.operator.io.AbstractExampleSource.read(AbstractExampleSource.java:49) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.operator.io.AbstractExampleSource.read(AbstractExampleSource.java:33) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.operator.io.AbstractReader.doWork(AbstractReader.java:126) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.operator.Operator.execute(Operator.java:1005) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:812) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:807) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at java.security.AccessController.doPrivileged(Native Method) [rt.jar:1.8.0_121]
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:428) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.Process.run(Process.java:1205) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.Process.run(Process.java:1101) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.Process.run(Process.java:1054) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at com.rapidminer.Process.run(Process.java:1049) [rapidminer-studio-core-7.4.0.jar:7.4.0]
at de.rapidanalytics.execution.AbstractProcessExecutor.runProcessNow(AbstractProcessExecutor.java:91) [rapidminer-server-ejb.jar:]
at de.rapidanalytics.execution.SimpleProcessExecutor.execute(SimpleProcessExecutor.java:31) [rapidminer-server-ejb.jar:]
at de.rapidanalytics.execution.ProcessExecutionDispatcher$ProcessRunnable.run(ProcessExecutionDispatcher.java:89) [rapidminer-server-ejb.jar:]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [rt.jar:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [rt.jar:1.8.0_121]
at java.lang.Thread.run(Thread.java:745) [rt.jar:1.8.0_121]
Caused by: java.lang.IllegalArgumentException: Twitter API access token is not set.
at com.rapidminer.operator.web.services.twitter.oauth.TwitterOAuth.getTwitterApi(TwitterOAuth.java:110)
at com.rapidminer.operator.web.services.twitter.oauth.TwitterConnection.getTwitterApi(TwitterConnection.java:61)
at com.rapidminer.operator.web.services.twitter.AbstractTwitterOperator.getTwitter(AbstractTwitterOperator.java:97)
... 22 more
18:36:17,015 SEVERE [com.rapidminer.Process.16] (scheduledprocess_1495823776993) Here: Process[1] (Process)
subprocess 'Main Process'
+- Subprocess (2)[0] (Subprocess)
subprocess 'Nested Process'
| +- Create Document (2)[0] (Create Document)
| +- Documents to Data (2)[0] (Documents to Data)
| +- Execute Script[0] (Execute Script)
| +- Extract Macro[0] (Extract Macro)
| +- Generate Data by User Specification[0] (Generate Data by User Specification)
| +- Enrich Data by Webservice (2)[0] (Enrich Data by Webservice)
| +- Extract Macro (2)[0] (Extract Macro)
+- Subprocess[0] (Subprocess)
| +- Create Document[0] (Create Document)
| +- Documents to Data[0] (Documents to Data)
| +- Encode URLs[0] (Encode URLs)
+- Enrich Data by Webservice[0] (Enrich Data by Webservice)
==> +- Search Twitter[1] (Search Twitter)
+- Retrieve Twitter[0] (Retrieve)
+- Append[0] (Append)
+- Remove Duplicates[0] (Remove Duplicates)
+- Sort[0] (Sort)
The issue seems to be that the token does not get saved properly. When I go BACK to the Connections window and click "Test Connection" again, I get an error:
Scott
When reproducing your problem I managed to fix it by setting the permissions for this connection.
Would you please check if they are set on your machine?
Another question which might also be interesting here: How did you trigger this process?
From Studio by clicking on "Execute on Server" or from the Server Webinterface?
Best,
Edin
Best,
Edin
Hi Scott,
sometimes there is an issue when it comes to setting access rights for Server connections from within Studio.
Would you please delete the connection and set it up within the Webinterface of RapidMiner Server, set the permissions there and test it.
If you get an error as well would you mind providing the log file for this event?
Best,
Edin
