Twitter connection problem
Hi...trying to build a twitter connection on RM Server 7.4 and I keep getting an error. Here's what I did:
- Added a Twitter connection on my server from the RM Studio "Add connection" interface.
- Tested with success.
- Added "admin" as user
- Save all changes.
- Logged into RM Server and went to Connections. The token is already pasted into the access_token window. When I click "Test Connection Parameters", I get "Test failed: Twitter API access token has incorrect format"
- Tried deleting the token and then literally copying and pasting the token manually from Studio to Server - same result.
Help?
Thanks.
Scott
