Altair RISE
Nominate Yourself Now!
Result window and pie chart - how to sum and group?
User: "puchatekkubus"
New Altair Community Member
Updated by Jocelyn
Hi,
I'm new to RapidMiner. First thing I want to do is to obtain pie chart from simple dataset.
In MySQL table I have columns: client_id; turnover (several records for each client).
I add "Read Database" component, run the process, on the "chart" window I select "chart style" pie and if I choose "group-by column" klient_id it does not work (no data available).
What should I do to sum "turnover" column and group by "client_id"?
Thanks for help
1 - 2 of 21
    User: "Edin_Klapic"
    Hi puchatekkubus,
    welcome to the RapidMiner Community! Great to have you here :)
    I recommend to use the Operator Aggregate right after Read Database. There you should Group by client_id and Aggregate the turnover as sum. Please be sure that your turnover Attribute is numerical!
    Afterwards the settings for the Pie chart should be:
    • Group-By: None
    • Legend: client_id
    • Value: sum(turnover)
    • Aggregation: none
    Hope this helps.
    Best,
    Edin
    OP
    Thank you very much indeed for help!
    It works :-)
    However I do not get why Group-By is  None.... should be client_id (looks like this parameter is never working).
    Regards
