"Read URL (CSV)
Hi,
I'm trying to use the Read URL-operator to get some financial data. This data is real-time, and I need to re-load it every now and then without having to manually download and edit the data. Example:
https://chartapi.finance.yahoo.com/instrument/1.0/AAPL/chartdata;type=quote;range=1d/csv
The Read URL fails because there are some lines on the top of the document (17 lines) that are only informational and not useful for the data set. I need to remove these lines.
Is there a way to remove or ignore these lines using RapidMiner operators?
