The Yahoo Historical Stock Data operator is in the Finance and Economic Data extension provided by BroadReachAnalytics. Visiting their URL provided in the RM documentation (http://www.broadreachanalytics.com/) it appears they are no longer active.
RapidMiner: Is there any opportunity to update this operator? Thanks.
Yes, I can confirm that this is no longer working and BroadReachAnalytics appears to be gone.
With RapidMiner, you can always find a work around and here it is.
<?xml version="1.0" encoding="UTF-8"?><process version="7.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="open_file" compatibility="7.4.000" expanded="true" height="68" name="Open File" width="90" x="45" y="34">
<parameter key="resource_type" value="URL"/>
<parameter key="url" value="http://www.google.com/finance/historical?q=NASDAQ:GOOGL&amp;ei=u5z8WJGtC8ejeeqWgbgJ&amp;output=csv"/>
</operator>
<operator activated="true" class="read_csv" compatibility="7.4.000" expanded="true" height="68" name="Read CSV" width="90" x="179" y="34">
<parameter key="column_separators" value=","/>
<list key="annotations"/>
<list key="data_set_meta_data_information"/>
</operator>
<connect from_op="Open File" from_port="file" to_op="Read CSV" to_port="file"/>
<connect from_op="Read CSV" from_port="output" to_port="result 1"/>
</process>
</operator>
</process>
Hi Thomas,
Thanks for that work around. I can confirm that it works pretty well with a single symbol. However, is there also a way to load multiple symbols at a time?
From your tutorials I know that it is possible to append several single symbols but in this case I want to download about 20. Searching the internet I found a site (LINK) which describes a select query but I couldn't manage to get this working in Rapidminer... ![]()
Kind regards
Sachs
Hi Sachs,
Piece of cake. Just make a text file with the header Ticker and then a new symbol on each line. Then use this process below. You should save them seperately in a repository by appending %{symbol}_stock
<context>
<input/>
<output/>
<macros/>
</context>
<parameter key="filename" value="C:\Users\ThomasOtt\Desktop\Ticker File.txt"/>
</operator>
</operator>
<operator activated="true" class="extract_macro" compatibility="7.4.000" expanded="true" height="68" name="Extract Macro (2)" width="90" x="313" y="34">
<parameter key="macro" value="num"/>
<list key="additional_macros"/>
</operator>
<operator activated="true" class="concurrency:loop" compatibility="7.4.000" expanded="true" height="82" name="Loop" width="90" x="514" y="34">
<parameter key="number_of_iterations" value="%{num}"/>
<operator activated="true" class="extract_macro" compatibility="7.4.000" expanded="true" height="68" name="Extract Macro" width="90" x="112" y="34">
<parameter key="macro" value="symbol"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="attribute_name" value="Ticker"/>
<parameter key="example_index" value="%{iteration}"/>
</operator>
<operator activated="true" class="open_file" compatibility="7.4.000" expanded="true" height="68" name="Open File (2)" width="90" x="112" y="136">
<parameter key="filename" value="http://www.google.com/finance/historical?q=NASDAQ:%{symbol}&amp;ei=LRD-WJmhHIOrmgH_4KToAg&amp;output=csv"/>
<parameter key="url" value="http://www.google.com/finance/historical?q=NASDAQ:%{symbol}&amp;ei=LRD-WJmhHIOrmgH_4KToAg&amp;output=csv"/>
</operator>
<operator activated="true" class="read_csv" compatibility="7.4.000" expanded="true" height="68" name="Read CSV (2)" width="90" x="447" y="85">
<parameter key="csv_file" value="http://www.google.com/finance/historical?q=NASDAQ:%{symbol}&amp;ei=LRD-WJmhHIOrmgH_4KToAg&amp;output=csv"/>
</operator>
<connect from_port="input 1" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Open File (2)" from_port="file" to_op="Read CSV (2)" to_port="file"/>
<connect from_op="Read CSV (2)" from_port="output" to_port="output 1"/>
<portSpacing port="source_input 2" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
</operator>
<connect from_op="Read CSV" from_port="output" to_op="Extract Macro (2)" to_port="example set"/>
<connect from_op="Extract Macro (2)" from_port="example set" to_op="Loop" to_port="input 1"/>
<connect from_op="Loop" from_port="output 1" to_port="result 1"/>
</process>
</operator>
</process>
Hi Pardeep.
Just do a search for how to do it on the Community. Here's a great response from Ingo: http://community.rapidminer.com/t5/RapidMiner-Studio-Forum/Import-XML-code-to-process/m-p/32606
Hi Thomas,
This already looks very promising - and brings the advantage to control stock symbols in separate external file. Pretty cool!
Now I am struggling with two more problems:
1) The process provides a collection but I rather want to have each symbol in its own column in a single example set / table.
2) I tried to access the yahoo web api with the open file operator:
But I couldn't manage to make the yahoo links work though they would do fine a web browser.
Lookling forward to getting some advice...
Cheers
Sachs
Yahoo did something to bork the whole thing recently, so I would default to Google right now.
With respect to putting it all in a table, I'd have to think about it but it would include using a Rename by Replacing so you can do AAPL_Close and XOM_Close and then something to merge them all together, maybe with a combination of a Remember and Recall operator but I need go AFK know.
Hi Pardeep.
Yes, I noticed the same thing. And another app I use to download data from Yahoo (YLoader) won't work either -- it throws a "HTTP response error 301"
Anyone else?
