Administrator privileges
Printil
Printil New Altair Community Member
edited November 2024 in Community Q&A
Dear sirs,
i'm using Rapidminer in a lab, where my studnets and I do not have administrator privileges. When running a very basic model with a logistic regression Rapidminer just closes without any error message.
The IT staff have already tried to solve this problem, but without the adminisitrator privileges thsi can not be solves.
Could you please let me know how to solve this issue?
Brst regards,
Ana
Welcome!
Answers
  • Thomas_Ott
    Thomas_Ott New Altair Community Member
    You can try the Linux version of RapidMiner and launch it from the windows.bat file.
  • Printil
    Thank you for your answer, but it doesn't work.
    Is there any other way?
    Best regards,
    ana
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hi,
    could you please provide log files?
    ~Martin
  • Printil
    Here you have the log:
    Jun 26, 2017 3:43:28 PM com.rapidminer.tools.I18N <clinit>
    INFO: Set locale to en.
    Jun 26, 2017 3:43:28 PM com.rapidminer.core.license.ProductConstraintManager initialize
    INFO: Initializing license manager.
    INFO: Using default license location.
    INFO: Registering default product.
    Jun 26, 2017 3:43:28 PM com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: Cloud Connectivity
    INFO: Register plugin: Cloud Execution
    INFO: Register plugin: Data Editor
    INFO: Register plugin: H2O
    INFO: Register plugin: Operator Recommender
    INFO: Register plugin: Process Scheduling
    INFO: Register plugin: Advanced File Connectors
    INFO: Register plugin: Concurrency
    INFO: Register plugin: JDBC Connectors
    INFO: Register plugin: Legacy Result Access
    INFO: Register plugin: Productivity
    INFO: Register plugin: Professional
    INFO: Register plugin: Remote Repository
    INFO: Register plugin: Text Processing
    INFO: Register plugin: Social Media
    Jun 26, 2017 3:43:29 PM com.rapidminer.tools.config.ConfigurationManager register
    INFO: Registered configurator Twitter Connection.
    INFO: Registered configurator Salesforce Connection.
    INFO: Registered configurator Amazon S3 Connection.
    INFO: Registered configurator Dropbox Connection.
    Jun 26, 2017 3:43:30 PM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties <init>
    WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
    WARNING: Missing database driver class name for Ingres
    Jun 26, 2017 3:43:30 PM com.rapidminer.tools.plugin.Plugin initAll
    INFO: Extension Text Processing was loaded in 31ms.
    INFO: Extension Operator Recommender was loaded in 93ms.
    INFO: Extension Data Editor was loaded in 93ms.
    INFO: Extension Concurrency was loaded in 94ms.
    INFO: Extension Productivity was loaded in 94ms.
    INFO: Extension Legacy Result Access was loaded in 94ms.
    INFO: Extension Remote Repository was loaded in 110ms.
    INFO: Extension Social Media was loaded in 110ms.
    INFO: Extension Advanced File Connectors was loaded in 125ms.
    INFO: Extension Professional was loaded in 156ms.
    INFO: Extension Cloud Execution was loaded in 171ms.
    INFO: Extension Cloud Connectivity was loaded in 188ms.
    INFO: Extension Process Scheduling was loaded in 281ms.
    INFO: Extension JDBC Connectors was loaded in 282ms.
    INFO: Extension H2O was loaded in 344ms.
    Jun 26, 2017 3:43:34 PM com.rapidminer.tools.config.ConfigurationManager loadConfiguration
    INFO: Load configuration for Amazon S3 Connection.
    Jun 26, 2017 3:43:34 PM com.rapidminer.tools.config.ClientConfigurationManager loadAllParameters
    INFO: No configuration file found for Amazon S3 Connection
    INFO: Loaded configurations for 0 objects of type Amazon S3 Connection.
    INFO: Load configuration for Dropbox Connection.
    INFO: No configuration file found for Dropbox Connection
    INFO: Loaded configurations for 0 objects of type Dropbox Connection.
    INFO: Load configuration for Salesforce Connection.
    INFO: No configuration file found for Salesforce Connection
    INFO: Loaded configurations for 0 objects of type Salesforce Connection.
    INFO: Load configuration for Twitter Connection.
    INFO: No configuration file found for Twitter Connection
    INFO: Loaded configurations for 0 objects of type Twitter Connection.
    Jun 26, 2017 3:43:36 PM com.rapidminer.deployment.update.client.MarketplaceUpdateManager$3 run
    INFO: Checking for updates.
    Jun 26, 2017 3:43:38 PM com.rapidminer.Process setProcessLocation
    INFO: Decoupling process from location C:\Users\exame\.RapidMiner\autosave\autosaved_process.xml. Process is now associated with file //Samples/processes/02_Preprocessing/03_Sampling.
    Jun 26, 2017 3:43:40 PM com.rapidminer.tools.WrapperLoggingHandler log
    INFO: No filename given for result file, using stdout for logging results!
    Jun 26, 2017 3:43:40 PM com.rapidminer.Process loadInitialData
    INFO: Loading initial data.
    Jun 26, 2017 3:43:40 PM com.rapidminer.Process run
    INFO: Process //Samples/processes/02_Preprocessing/03_Sampling starts
    Jun 26, 2017 3:43:40 PM com.rapidminer.h2o.ClusterManager startCluster
    INFO: Starting up embdedded H2O cluster rm-h2o-cluster-298317 with 1 threads.
    I also get the following error message:
    Thank you.
    Best regards,
    Vera Miguéis
  • nmahesh
    nmahesh New Altair Community Member
    Hi Vera,
    I think the issue could be with the repository location in regards to the: Missing database driver class name for ODBC Bridge (e.g. Access) warning your getting. The repository location expects locations in the RapidMiner repository not on the file system. If you have a repository called 'Test' a valid location would be new RepositoryLocation("//test/folder1/process/"). Another thing you could try is unchecking "resolve relative to" choice from your operators and then selecting by absolute repository locations.
    Best,
    Nithin Mahesh
Welcome!
Welcome!
