Weka Random forest constantly better than Random Forest Rapidminer
hi,
I teste W-RAndom Forest and Random Forest from Rapidminer on the same dataset, for W-RF, I got around 89%, whereas for Random Forest I got only 76%, why is that? I thought the Algorithm / Method is the same? Are the implementations so entirely different that I get such a performance discrepancy?
1 - 3 of
31
Are you comparing it with the same splitting criteron? This post says that W-RF uses information criteron to split: http://stackoverflow.com/questions/30150970/what-splitting-criterion-does-random-tree-in-weka-3-7-11-use-for-numerical-attri
When I do that, the results of the attached Iris data set works the same.
