1 - 3 of
31
I would never have a Write CSV inside the testing partion of the Cross Validation operator. If the k value is set to 10, that CSV file will be over written 10 times and you won't be sure that what you see is the best Performance because of the randomness of the split. If you want to store the performance, whether in CSV or some other format, do that outside the Cross VAlidation operator via the PER port.
Since you are using the Optimize Parameters operator, just put your Perf to Data & Write CSV operator on the outside of the Optmize Parameter operator and connect the PER port to them. Then you'll get the Optimzed Performance.
I don't understand what you want to do. Are you exceeding the maximum 10,000 rows? Can you post a screenshot of the error you encounter?
