How to make the annotations in Charts / Graphs bigger?
Fred12
Fred12 New Altair Community Member
edited November 2024 in Community Q&A
hi,
I have some charts here saved as pdf vector format ( or as png) but somehow, the annotations / Text on the charting axes etc. is too small to be read when printed out... is there some way to make them bigger? in some hidden settings of Rapidminer maybe or in the charts itself? I did not find such an option... alternatively.. what could I do to make them bigger or more readable?
Welcome!
Best Answers
  • Thomas_Ott
    Thomas_Ott New Altair Community Member
    Answer ✓
    Are you using the advanced charts? Isn't there an "Item Size" under configuration?
  • Fred12
    Answer ✓
    hmm indeed, there is global configuration -> Font size, didn't see it, thanks...
    edit: In advanced charts, it works, but what about Deviation Charts in normal charting? any options for that? Or can I set up / configure same deviation charts somehow in the advanced charts?
  • JEdward
    JEdward New Altair Community Member
    Answer ✓
    Yes, you can use File & Print/Export Image to export the chart as an SVG.
    Then open it up in a friendly SVG editor and annotate away!
    Have a look at this post on doing it with Process images & yes, it also works with chart exports.
    https://rapidminer.com/exporting-scalable-images/
    Protip: if you have a lot of images you want to produce or with the same plot settings over & over again you can use the Reporting extension.  Set the export type to HTML and save images as SVG.  Now you can get all the plots you want as SVG for editing.  (I'm sure smarter folk than I can suggest ways of automating SVG editing too, but until then you'll need to do that part with a bit of manual effort).
Answers
  • Thomas_Ott
    Answer ✓
  • Fred12
    Answer ✓
  • Fred12
    is there a solution for normal chart? I need bigger annotations for deviation plot... and others
  • JEdward
    Answer ✓
  • Fred12
    thanks, thats really nice!
    what program do you use to manipulate vector graphics? are there maybe simpler programs than Inkscape? I cant ungroup them or don't know how to do it -.-
  • Thomas_Ott
    Hi Fred, I've used Inkscape and GIMP in the past. I usally put each image on a layer (in GIMP) and then export it as a new one
  • Fred12
    ok hmm I don't know how to use both programs...
    I used corel draw X7 it works nice, I can choose all individual elements, move them or make them biggger but how can I automatically choose all numbers on the y- and x-axis of a graph and make the characters bigger all at once? I for now have to klick every number and make it bigger manually, which is tedious to do...
  • JEdward
    One of my team pointed me to this website recently.  http://editor.method.ac/   (Thanks Jonas!)
    It's a free editor for SVG that is really simple to use.
    Try it out.
  • Fred12
    ok thanks, but this works for svg only, I use pdf with latex only (somehow svg does not work with the settings..)
Welcome!
Welcome!
