"Loading Adobe/Word into Rapidminer"
ben_buhl
ben_buhl New Altair Community Member
edited November 2024 in Community Q&A
Hi All,
I want to load some Adobe documents into Rapidminer so I can calculate word frequencies.  I am able to do this with Excel sheets but can't seem to load the Adobe doc into it.  Please let me know what operators I need to load either Adobe or Word docs into Rapidminer to calculate word frequencies.
Thanks.
Welcome!
Answers
  • Thomas_Ott
    Thomas_Ott New Altair Community Member
    You can load PDF, TXT, HTML, and XML files only. DOCX is not supported.
  • ben_buhl
    Thank you, that is helpful.  Can you tell me what operators I will need to make this work?
  • Thomas_Ott
    Sure. If the files are in a directory, then use the Process Documets from Folders operator. This operator is found in the Text Processing extension available on the marketplace.
  • JEdward
    JEdward New Altair Community Member
    Actually reading DOCX is supported as well.  Please see this sample process.
    <?xml version="1.0" encoding="UTF-8"?><process version="7.4.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.4.000" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="open_file" compatibility="7.4.000" expanded="true" height="68" name="Open File" width="90" x="246" y="187">
    <parameter key="filename" value="C:\Users\think\Documents\MyWordDoc.docx"/>
    </operator>
    <operator activated="true" class="loop_zipfile_entries" compatibility="7.4.000" expanded="true" height="82" name="Read Word Document" width="90" x="581" y="187">
    <parameter key="internal_directory" value="word"/>
    <parameter key="filter" value="document\.xml"/>
    <operator activated="true" class="text:read_document" compatibility="7.4.001" expanded="true" height="68" name="Read Document" width="90" x="179" y="238">
    <parameter key="content_type" value="xml"/>
    </operator>
    <connect from_port="file object" to_op="Read Document" to_port="file"/>
    <connect from_op="Read Document" from_port="output" to_port="out 1"/>
    <portSpacing port="source_file object" spacing="0"/>
    <portSpacing port="source_in 1" spacing="0"/>
    <portSpacing port="sink_out 1" spacing="0"/>
    <portSpacing port="sink_out 2" spacing="0"/>
    </process>
    </operator>
    <connect from_op="Open File" from_port="file" to_op="Read Word Document" to_port="file"/>
    <connect from_op="Read Word Document" from_port="out 1" to_port="result 1"/>
    </process>
    </operator>
    </process>
  • Thomas_Ott
    Huh, will you look at that. You taught me a new trick @JEdward! Thanks!
  • JEdward
    MSOffice documents are actually just zip files.
    It also works with PPTX documents too, but you need to do need to change the Loop Zip Files from my example to loop through each slide as they store them in separate XML documents.
    Have fun!
Welcome!
Welcome!
