Example Set from Logdata -> saving in repository -> Less examples -> Bug?
hi,
I have a logdata with parameteroptimizing, I get about 50 combinations in x-validation and therefore in my logdata as examples. Now, if I transform log into Example Set and inspect results at the end, everything is OK, there are 50 examples in the example set.. however, if I store the example set in the repository then, and retrieve it to inspect it, only a part of the examples have been stored!! Like sometimes 17, 19 or 27 examples... I donÄt know why.. I have enough disk space on my PC... thats very weird and especially bad if I want to reconstruct some graphs in the later from my results.. ![]()
Did anybody encouter the same problem before?
actually yes, its inside the parameter optimization operator..
I noticed at the end when it gives out the results.. its only part of the data, but when I click on show example set result after it finished, it gives the full data.. and when I save it, It also saves the full data... just wondered me that it does not do this in the first place when the process has finished...
I have not. Are you using any of the sorting in the Log operattion? Like Top K sorting? That might cause it skip the order of some examples.
