Getting "+ Add Data" instead of the normal output
I am getting "+ Add Data" instead of the normal output results - models and predicted values. This just started about 15 minutes ago...and I am not sure why. I am currently using the free community version of RapidMiner and all was going well for months...Then about 15 minutes ago I started experiencing the above issue on all my stored processes. The input datasets are very small (< 500 examples).
1 - 4 of
41
1 - 1 of
11
Ah, you must've closed your process design window. Just go to View > Restore View and everything will show up again.
Hey,
could you post a screenshot?
~Martin
