Thanks for your reply,
that sounds pretty good. But could you specify? I downloaded the operator toolbox, but as soon as I put the Group into Collection operator into the Loop Collection operator the Error Message "Expected IOObjectCollection but received Examples set" occurs. Since I would call myself a newbie I would be grateful if you could provide me how to do so :-).
Regards
Philipp
Hi,
i currently cannot run you proces, but i think you need to use an append before the join to get an example set again.
Edit: For the two attributes. Thats on our list to add. The Toolbox extension is a community like extension, even tough it is a rapidminer-interal community . So far you need to go for Generate Attribute and Concat to do two attributes.
Loop Values with Filter Example is by the way also a viable option, but slightly slower in execution time.
~Martin
Oh, okay. That's maybe because I have so many dataset etc.
But if I append now I have the same result as before. What I whant to do is to join every collection in this case e.g. 365 with another example set (which contains e.g. the name of the days of the week). So to append wouldn't be an option or?
I think you need to get the data set into your loop collection using remember recall. See attached process
With 1-2 more operators we could use a usual loop, with select operator. The standard loop has an additional input and is working in parallel. Quite some options to go there .
Best,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="7.3.001" expanded="true" height="68" name="Read CSV" width="90" x="45" y="85">
<parameter key="csv_file" value="/Users/Philipp/Desktop/Tank_Muenster.csv"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="encoding" value="UTF-8"/>
<list key="data_set_meta_data_information">
<parameter key="0" value="brand.true.polynominal.attribute"/>
<parameter key="1" value="name.true.polynominal.attribute"/>
<parameter key="2" value="Day.true.polynominal.attribute"/>
<parameter key="3" value="Time.true.polynominal.attribute"/>
<parameter key="4" value="street.true.polynominal.attribute"/>
<parameter key="5" value="lat.true.real.attribute"/>
<parameter key="6" value="lng.true.real.attribute"/>
<parameter key="7" value="place.true.polynominal.attribute"/>
<parameter key="8" value="post_code.true.integer.attribute"/>
<parameter key="9" value="Benzin e5 in ¨.true.polynominal.attribute"/>
<parameter key="10" value="Diesel in ¨.true.polynominal.attribute"/>
<parameter key="11" value="stid.true.polynominal.attribute"/>
<parameter key="12" value="TagdW.true.polynominal.attribute"/>
<parameter key="13" value="Feiertag.true.polynominal.attribute"/>
</list>
</operator>
<operator activated="true" class="nominal_to_date" compatibility="7.3.001" expanded="true" height="82" name="Nominal to Date" width="90" x="179" y="85">
<parameter key="attribute_name" value="Time"/>
<parameter key="date_type" value="time"/>
<parameter key="date_format" value="h:mm a"/>
<parameter key="locale" value="German (Germany)"/>
</operator>
<operator activated="true" class="date_to_numerical" compatibility="7.3.001" expanded="true" height="82" name="Date to Numerical (2)" width="90" x="313" y="85">
<parameter key="time_unit" value="minute"/>
<parameter key="minute_relative_to" value="day"/>
</operator>
<operator activated="true" class="generate_attributes" compatibility="7.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="85">
<list key="function_descriptions">
<parameter key="Grid" value="if(Time>0&&Time<=15,15, if(Time>15&&Time<=30,30, if(Time>30&&Time<=45,45, if(Time>45&&Time<=60,60, if(Time>60&&Time<=75,75, if(Time>75&&Time<=90,90, if(Time>90&&Time<=105,105, if(Time>105&&Time<=120,120, if(Time>120&&Time<=135,135, if(Time>135&&Time<=150,150, if(Time>150&&Time<=165,165, if(Time>165&&Time<=180,180, if(Time>180&&Time<=195,195, if(Time>195&&Time<=210,210, if(Time>210&&Time<=225,225, if(Time>225&&Time<=240,240, if(Time>240&&Time<=255,255, if(Time>255&&Time<=270,270, if(Time>270&&Time<=285,285, if(Time>285&&Time<=300,300, if(Time>300&&Time<=315,315, if(Time>315&&Time<=330,330, if(Time>330&&Time<=345,345, if(Time>345&&Time<=360,360, if(Time>360&&Time<=375,375, if(Time>375&&Time<=390,390, if(Time>390&&Time<=405,405, if(Time>405&&Time<=420,420, if(Time>420&&Time<=435,435, if(Time>435&&Time<=450,450, if(Time>450&&Time<=465,465, if(Time>465&&Time<=480,480, if(Time>480&&Time<=495,495, if(Time>495&&Time<=510,510, if(Time>510&&Time<=525,525, if(Time>525&&Time<=540,540, if(Time>540&&Time<=555,555, if(Time>555&&Time<=570,570, if(Time>570&&Time<=585,585, if(Time>585&&Time<=600,600, if(Time>600&&Time<=615,615, if(Time>615&&Time<=630,630, if(Time>630&&Time<=645,645, if(Time>645&&Time<=660,660, if(Time>660&&Time<=675,675, if(Time>675&&Time<=690,690, if(Time>690&&Time<=705,705, if(Time>705&&Time<=720,720, if(Time>720&&Time<=735,735, if(Time>735&&Time<=750,750, if(Time>750&&Time<=765,765, if(Time>765&&Time<=780,780, if(Time>780&&Time<=795,795, if(Time>795&&Time<=810,810, if(Time>810&&Time<=825,825, if(Time>825&&Time<=840,840, if(Time>840&&Time<=855,855, if(Time>855&&Time<=870,870, if(Time>870&&Time<=885,885, if(Time>885&&Time<=900,900, if(Time>900&&Time<=915,915, if(Time>915&&Time<=930,930, if(Time>930&&Time<=945,945, if(Time>945&&Time<=960,960, if(Time>960&&Time<=975,975, if(Time>975&&Time<=990,990, if(Time>990&&Time<=1005,1005, if(Time>1005&&Time<=1020,1020, if(Time>1020&&Time<=1035,1035, if(Time>1035&&Time<=1050,1050, if(Time>1050&&Time<=1065,1065, if(Time>1065&&Time<=1080,1080, if(Time>1080&&Time<=1095,1095, if(Time>1095&&Time<=1110,1110, if(Time>1110&&Time<=1125,1125, if(Time>1125&&Time<=1140,1140, if(Time>1140&&Time<=1155,1155, if(Time>1155&&Time<=1170,1170, if(Time>1170&&Time<=1185,1185, if(Time>1185&&Time<=1200,1200, if(Time>1200&&Time<=1215,1215, if(Time>1215&&Time<=1230,1230, if(Time>1230&&Time<=1245,1245, if(Time>1245&&Time<=1260,1260, if(Time>1260&&Time<=1275,1275, if(Time>1275&&Time<=1290,1290, if(Time>1290&&Time<=1305,1305, if(Time>1305&&Time<=1320,1320, if(Time>1320&&Time<=1335,1335, if(Time>1335&&Time<=1350,1350, if(Time>1350&&Time<=1365,1365, if(Time>1365&&Time<=1380,1380, if(Time>1380&&Time<=1395,1395, if(Time>1395&&Time<=1410,1410, if(Time>1410&&Time<=1425,1425, if(Time>1425&&Time<=1440,1440,666)))) ))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))"/>
</list>
</operator>
<operator activated="true" class="numerical_to_real" compatibility="7.3.001" expanded="true" height="82" name="Numerical to Real" width="90" x="313" y="238">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="Grid"/>
</operator>
<operator activated="true" class="read_excel" compatibility="7.3.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="391">
<parameter key="excel_file" value="/Users/Philipp/Desktop/Zeit_.xlsx"/>
<parameter key="imported_cell_range" value="A1:B97"/>
</list>
<parameter key="0" value="Time.true.time.attribute"/>
<parameter key="1" value="Timegrid.true.time.attribute"/>
</list>
</operator>
<operator activated="true" class="date_to_numerical" compatibility="7.3.001" expanded="true" height="82" name="Date to Numerical" width="90" x="179" y="391">
</operator>
<operator activated="true" class="date_to_numerical" compatibility="7.3.001" expanded="true" height="82" name="Date to Numerical (3)" width="90" x="313" y="391">
<parameter key="attribute_name" value="Timegrid"/>
</operator>
<operator activated="true" class="numerical_to_real" compatibility="7.3.001" expanded="true" height="82" name="Numerical to Real (2)" width="90" x="447" y="391"/>
<operator activated="true" class="remember" compatibility="7.3.001" expanded="true" height="68" name="Remember" width="90" x="581" y="391">
<parameter key="name" value="data"/>
</operator>
<operator activated="true" class="operator_toolbox:group_into_collection" compatibility="0.1.000" expanded="true" height="82" name="Group Into Collection (2)" width="90" x="447" y="238">
<parameter key="group_by_attribute" value="Day"/>
</operator>
<operator activated="true" class="delay" compatibility="7.3.001" expanded="true" height="103" name="Delay" width="90" x="648" y="238">
<parameter key="delay" value="none"/>
<description align="center" color="transparent" colored="false" width="126">Just to ensure execution order</description>
</operator>
<operator activated="true" class="loop_collection" compatibility="7.3.001" expanded="true" height="82" name="Loop Collection" width="90" x="782" y="238">
<operator activated="false" class="operator_toolbox:group_into_collection" compatibility="0.1.000" expanded="true" height="82" name="Group Into Collection" width="90" x="112" y="238">
<parameter key="group_by_attribute" value="stid"/>
</operator>
<operator activated="true" class="recall" compatibility="7.3.001" expanded="true" height="68" name="Recall" width="90" x="112" y="85">
</operator>
<operator activated="true" class="join" compatibility="7.3.001" expanded="true" height="82" name="Join" width="90" x="246" y="34">
<parameter key="remove_double_attributes" value="false"/>
<parameter key="join_type" value="right"/>
<parameter key="use_id_attribute_as_key" value="false"/>
<list key="key_attributes">
<parameter key="Grid" value="Time"/>
</list>
</operator>
<connect from_port="single" to_op="Join" to_port="left"/>
<connect from_op="Recall" from_port="result" to_op="Join" to_port="right"/>
<connect from_op="Join" from_port="join" to_port="output 1"/>
<portSpacing port="source_single" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
</operator>
<connect from_op="Read CSV" from_port="output" to_op="Nominal to Date" to_port="example set input"/>
<connect from_op="Nominal to Date" from_port="example set output" to_op="Date to Numerical (2)" to_port="example set input"/>
<connect from_op="Date to Numerical (2)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Numerical to Real" to_port="example set input"/>
<connect from_op="Numerical to Real" from_port="example set output" to_op="Group Into Collection (2)" to_port="exa"/>
<connect from_op="Read Excel" from_port="output" to_op="Date to Numerical" to_port="example set input"/>
<connect from_op="Date to Numerical" from_port="example set output" to_op="Date to Numerical (3)" to_port="example set input"/>
<connect from_op="Date to Numerical (3)" from_port="example set output" to_op="Numerical to Real (2)" to_port="example set input"/>
<connect from_op="Numerical to Real (2)" from_port="example set output" to_op="Remember" to_port="store"/>
<connect from_op="Remember" from_port="stored" to_op="Delay" to_port="through 2"/>
<connect from_op="Group Into Collection (2)" from_port="col" to_op="Delay" to_port="through 1"/>
<connect from_op="Delay" from_port="through 1" to_op="Loop Collection" to_port="collection"/>
<connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/>
</process>
</operator>
</process>
Could you check if the remember operator is executed before the recall?
Best,
Martin
Okay that worked. Thank you! I think it's the routine, which hopefully lets me find this kind of solutions, too.
The whole process is finished now. It works fine, but is would there be a way to create or rather get back the meta data? It took me some typing to manually write all attribute names in a couple of different operators.
Best,
Martin
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</list>
</operator>
</operator>
</operator>
</list>
</operator>
</operator>
</list>
</list>
</operator>
</operator>
</operator>
</operator>
</operator>
</operator>
</operator>
</operator>
</list>
</operator>
</process>
</operator>
</process>
</operator>
</process>
Hey,
loop values would do the job. Maybe our new Group Into Collection operator from the Operator Toolbox is even better, it gives you a collection with an example set per day. You can work with Loop Collection trhough the days.
~Martin
