🎉Community Raffle - Win $25
Join and Win
How to "loop" over a filter?
User: "eldenoso"
New Altair Community Member
Updated by Jocelyn
Hey everybody,
I have a dataset containing the hours of a day of the whole year. What I want to do is to filter each day. Obviously doing that manually would be very hard, as I had to do that 365 times. Is there a way to somehow loop this thing?
1 - 1 of 11
    User: "MartinLiebig"
    Accepted Answer
    I think you need to get the data set into your loop collection using remember recall. See attached process
    With 1-2 more operators we could use a usual loop, with select operator. The standard loop has an additional input and is working in parallel. Quite some options to go there :).
    Best,
    Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="7.3.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="read_csv" compatibility="7.3.001" expanded="true" height="68" name="Read CSV" width="90" x="45" y="85">
    <parameter key="csv_file" value="/Users/Philipp/Desktop/Tank_Muenster.csv"/>
    <parameter key="first_row_as_names" value="false"/>
    <list key="annotations">
    <parameter key="0" value="Name"/>
    </list>
    <parameter key="encoding" value="UTF-8"/>
    <parameter key="0" value="brand.true.polynominal.attribute"/>
    <parameter key="1" value="name.true.polynominal.attribute"/>
    <parameter key="2" value="Day.true.polynominal.attribute"/>
    <parameter key="3" value="Time.true.polynominal.attribute"/>
    <parameter key="4" value="street.true.polynominal.attribute"/>
    <parameter key="5" value="lat.true.real.attribute"/>
    <parameter key="6" value="lng.true.real.attribute"/>
    <parameter key="7" value="place.true.polynominal.attribute"/>
    <parameter key="8" value="post_code.true.integer.attribute"/>
    <parameter key="9" value="Benzin e5 in ¨.true.polynominal.attribute"/>
    <parameter key="10" value="Diesel in ¨.true.polynominal.attribute"/>
    <parameter key="11" value="stid.true.polynominal.attribute"/>
    <parameter key="12" value="TagdW.true.polynominal.attribute"/>
    <parameter key="13" value="Feiertag.true.polynominal.attribute"/>
    </list>
    <operator activated="true" class="nominal_to_date" compatibility="7.3.001" expanded="true" height="82" name="Nominal to Date" width="90" x="179" y="85">
    <parameter key="attribute_name" value="Time"/>
    <parameter key="date_type" value="time"/>
    <parameter key="date_format" value="h:mm a"/>
    <parameter key="locale" value="German (Germany)"/>
    <operator activated="true" class="date_to_numerical" compatibility="7.3.001" expanded="true" height="82" name="Date to Numerical (2)" width="90" x="313" y="85">
    <parameter key="time_unit" value="minute"/>
    <parameter key="minute_relative_to" value="day"/>
    <operator activated="true" class="generate_attributes" compatibility="7.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="85">
    <parameter key="Grid" value="if(Time&gt;0&amp;&amp;Time&lt;=15,15,&#10;if(Time&gt;15&amp;&amp;Time&lt;=30,30,&#10;if(Time&gt;30&amp;&amp;Time&lt;=45,45,&#10;if(Time&gt;45&amp;&amp;Time&lt;=60,60,&#10;if(Time&gt;60&amp;&amp;Time&lt;=75,75,&#10;if(Time&gt;75&amp;&amp;Time&lt;=90,90,&#10;if(Time&gt;90&amp;&amp;Time&lt;=105,105,&#10;if(Time&gt;105&amp;&amp;Time&lt;=120,120,&#10;if(Time&gt;120&amp;&amp;Time&lt;=135,135,&#10;if(Time&gt;135&amp;&amp;Time&lt;=150,150,&#10;if(Time&gt;150&amp;&amp;Time&lt;=165,165,&#10;if(Time&gt;165&amp;&amp;Time&lt;=180,180,&#10;if(Time&gt;180&amp;&amp;Time&lt;=195,195,&#10;if(Time&gt;195&amp;&amp;Time&lt;=210,210,&#10;if(Time&gt;210&amp;&amp;Time&lt;=225,225,&#10;if(Time&gt;225&amp;&amp;Time&lt;=240,240,&#10;if(Time&gt;240&amp;&amp;Time&lt;=255,255,&#10;if(Time&gt;255&amp;&amp;Time&lt;=270,270,&#10;if(Time&gt;270&amp;&amp;Time&lt;=285,285,&#10;if(Time&gt;285&amp;&amp;Time&lt;=300,300,&#10;if(Time&gt;300&amp;&amp;Time&lt;=315,315,&#10;if(Time&gt;315&amp;&amp;Time&lt;=330,330,&#10;if(Time&gt;330&amp;&amp;Time&lt;=345,345,&#10;if(Time&gt;345&amp;&amp;Time&lt;=360,360,&#10;if(Time&gt;360&amp;&amp;Time&lt;=375,375,&#10;if(Time&gt;375&amp;&amp;Time&lt;=390,390,&#10;if(Time&gt;390&amp;&amp;Time&lt;=405,405,&#10;if(Time&gt;405&amp;&amp;Time&lt;=420,420,&#10;if(Time&gt;420&amp;&amp;Time&lt;=435,435,&#10;if(Time&gt;435&amp;&amp;Time&lt;=450,450,&#10;if(Time&gt;450&amp;&amp;Time&lt;=465,465,&#10;if(Time&gt;465&amp;&amp;Time&lt;=480,480,&#10;if(Time&gt;480&amp;&amp;Time&lt;=495,495,&#10;if(Time&gt;495&amp;&amp;Time&lt;=510,510,&#10;if(Time&gt;510&amp;&amp;Time&lt;=525,525,&#10;if(Time&gt;525&amp;&amp;Time&lt;=540,540,&#10;if(Time&gt;540&amp;&amp;Time&lt;=555,555,&#10;if(Time&gt;555&amp;&amp;Time&lt;=570,570,&#10;if(Time&gt;570&amp;&amp;Time&lt;=585,585,&#10;if(Time&gt;585&amp;&amp;Time&lt;=600,600,&#10;if(Time&gt;600&amp;&amp;Time&lt;=615,615,&#10;if(Time&gt;615&amp;&amp;Time&lt;=630,630,&#10;if(Time&gt;630&amp;&amp;Time&lt;=645,645,&#10;if(Time&gt;645&amp;&amp;Time&lt;=660,660,&#10;if(Time&gt;660&amp;&amp;Time&lt;=675,675,&#10;if(Time&gt;675&amp;&amp;Time&lt;=690,690,&#10;if(Time&gt;690&amp;&amp;Time&lt;=705,705,&#10;if(Time&gt;705&amp;&amp;Time&lt;=720,720,&#10;if(Time&gt;720&amp;&amp;Time&lt;=735,735,&#10;if(Time&gt;735&amp;&amp;Time&lt;=750,750,&#10;if(Time&gt;750&amp;&amp;Time&lt;=765,765,&#10;if(Time&gt;765&amp;&amp;Time&lt;=780,780,&#10;if(Time&gt;780&amp;&amp;Time&lt;=795,795,&#10;if(Time&gt;795&amp;&amp;Time&lt;=810,810,&#10;if(Time&gt;810&amp;&amp;Time&lt;=825,825,&#10;if(Time&gt;825&amp;&amp;Time&lt;=840,840,&#10;if(Time&gt;840&amp;&amp;Time&lt;=855,855,&#10;if(Time&gt;855&amp;&amp;Time&lt;=870,870,&#10;if(Time&gt;870&amp;&amp;Time&lt;=885,885,&#10;if(Time&gt;885&amp;&amp;Time&lt;=900,900,&#10;if(Time&gt;900&amp;&amp;Time&lt;=915,915,&#10;if(Time&gt;915&amp;&amp;Time&lt;=930,930,&#10;if(Time&gt;930&amp;&amp;Time&lt;=945,945,&#10;if(Time&gt;945&amp;&amp;Time&lt;=960,960,&#10;if(Time&gt;960&amp;&amp;Time&lt;=975,975,&#10;if(Time&gt;975&amp;&amp;Time&lt;=990,990,&#10;if(Time&gt;990&amp;&amp;Time&lt;=1005,1005,&#10;if(Time&gt;1005&amp;&amp;Time&lt;=1020,1020,&#10;if(Time&gt;1020&amp;&amp;Time&lt;=1035,1035,&#10;if(Time&gt;1035&amp;&amp;Time&lt;=1050,1050,&#10;if(Time&gt;1050&amp;&amp;Time&lt;=1065,1065,&#10;if(Time&gt;1065&amp;&amp;Time&lt;=1080,1080,&#10;if(Time&gt;1080&amp;&amp;Time&lt;=1095,1095,&#10;if(Time&gt;1095&amp;&amp;Time&lt;=1110,1110,&#10;if(Time&gt;1110&amp;&amp;Time&lt;=1125,1125,&#10;if(Time&gt;1125&amp;&amp;Time&lt;=1140,1140,&#10;if(Time&gt;1140&amp;&amp;Time&lt;=1155,1155,&#10;if(Time&gt;1155&amp;&amp;Time&lt;=1170,1170,&#10;if(Time&gt;1170&amp;&amp;Time&lt;=1185,1185,&#10;if(Time&gt;1185&amp;&amp;Time&lt;=1200,1200,&#10;if(Time&gt;1200&amp;&amp;Time&lt;=1215,1215,&#10;if(Time&gt;1215&amp;&amp;Time&lt;=1230,1230,&#10;if(Time&gt;1230&amp;&amp;Time&lt;=1245,1245,&#10;if(Time&gt;1245&amp;&amp;Time&lt;=1260,1260,&#10;if(Time&gt;1260&amp;&amp;Time&lt;=1275,1275,&#10;if(Time&gt;1275&amp;&amp;Time&lt;=1290,1290,&#10;if(Time&gt;1290&amp;&amp;Time&lt;=1305,1305,&#10;if(Time&gt;1305&amp;&amp;Time&lt;=1320,1320,&#10;if(Time&gt;1320&amp;&amp;Time&lt;=1335,1335,&#10;if(Time&gt;1335&amp;&amp;Time&lt;=1350,1350,&#10;if(Time&gt;1350&amp;&amp;Time&lt;=1365,1365,&#10;if(Time&gt;1365&amp;&amp;Time&lt;=1380,1380,&#10;if(Time&gt;1380&amp;&amp;Time&lt;=1395,1395,&#10;if(Time&gt;1395&amp;&amp;Time&lt;=1410,1410,&#10;if(Time&gt;1410&amp;&amp;Time&lt;=1425,1425,&#10;if(Time&gt;1425&amp;&amp;Time&lt;=1440,1440,666))))&#10;))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))"/>
    </list>
    <operator activated="true" class="numerical_to_real" compatibility="7.3.001" expanded="true" height="82" name="Numerical to Real" width="90" x="313" y="238">
    <parameter key="attribute" value="Grid"/>
    <operator activated="true" class="read_excel" compatibility="7.3.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="391">
    <parameter key="excel_file" value="/Users/Philipp/Desktop/Zeit_.xlsx"/>
    <parameter key="imported_cell_range" value="A1:B97"/>
    </list>
    <parameter key="0" value="Time.true.time.attribute"/>
    <parameter key="1" value="Timegrid.true.time.attribute"/>
    </list>
    <operator activated="true" class="date_to_numerical" compatibility="7.3.001" expanded="true" height="82" name="Date to Numerical" width="90" x="179" y="391">
    <operator activated="true" class="date_to_numerical" compatibility="7.3.001" expanded="true" height="82" name="Date to Numerical (3)" width="90" x="313" y="391">
    <parameter key="attribute_name" value="Timegrid"/>
    <operator activated="true" class="numerical_to_real" compatibility="7.3.001" expanded="true" height="82" name="Numerical to Real (2)" width="90" x="447" y="391"/>
    <operator activated="true" class="remember" compatibility="7.3.001" expanded="true" height="68" name="Remember" width="90" x="581" y="391">
    <parameter key="name" value="data"/>
    <operator activated="true" class="operator_toolbox:group_into_collection" compatibility="0.1.000" expanded="true" height="82" name="Group Into Collection (2)" width="90" x="447" y="238">
    <parameter key="group_by_attribute" value="Day"/>
    <operator activated="true" class="delay" compatibility="7.3.001" expanded="true" height="103" name="Delay" width="90" x="648" y="238">
    <parameter key="delay" value="none"/>
    <description align="center" color="transparent" colored="false" width="126">Just to ensure execution order</description>
    <operator activated="true" class="loop_collection" compatibility="7.3.001" expanded="true" height="82" name="Loop Collection" width="90" x="782" y="238">
    <operator activated="false" class="operator_toolbox:group_into_collection" compatibility="0.1.000" expanded="true" height="82" name="Group Into Collection" width="90" x="112" y="238">
    <parameter key="group_by_attribute" value="stid"/>
    <operator activated="true" class="recall" compatibility="7.3.001" expanded="true" height="68" name="Recall" width="90" x="112" y="85">
    <operator activated="true" class="join" compatibility="7.3.001" expanded="true" height="82" name="Join" width="90" x="246" y="34">
    <parameter key="remove_double_attributes" value="false"/>
    <parameter key="join_type" value="right"/>
    <parameter key="use_id_attribute_as_key" value="false"/>
    <list key="key_attributes">
    <parameter key="Grid" value="Time"/>
    </list>
    <connect from_port="single" to_op="Join" to_port="left"/>
    <connect from_op="Recall" from_port="result" to_op="Join" to_port="right"/>
    <connect from_op="Join" from_port="join" to_port="output 1"/>
    <portSpacing port="source_single" spacing="0"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    <connect from_op="Read CSV" from_port="output" to_op="Nominal to Date" to_port="example set input"/>
    <connect from_op="Nominal to Date" from_port="example set output" to_op="Date to Numerical (2)" to_port="example set input"/>
    <connect from_op="Date to Numerical (2)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_op="Numerical to Real" to_port="example set input"/>
    <connect from_op="Numerical to Real" from_port="example set output" to_op="Group Into Collection (2)" to_port="exa"/>
    <connect from_op="Read Excel" from_port="output" to_op="Date to Numerical" to_port="example set input"/>
    <connect from_op="Date to Numerical" from_port="example set output" to_op="Date to Numerical (3)" to_port="example set input"/>
    <connect from_op="Date to Numerical (3)" from_port="example set output" to_op="Numerical to Real (2)" to_port="example set input"/>
    <connect from_op="Numerical to Real (2)" from_port="example set output" to_op="Remember" to_port="store"/>
    <connect from_op="Remember" from_port="stored" to_op="Delay" to_port="through 2"/>
    <connect from_op="Group Into Collection (2)" from_port="col" to_op="Delay" to_port="through 1"/>
    <connect from_op="Delay" from_port="through 1" to_op="Loop Collection" to_port="collection"/>
    <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/>
    </process>
    </process>
