Why following force displacement is lager?
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
I am practice the example like this connect
https://altairuniversity.com/analysis/structural/nonlinear/beam-comparison-to-nlstat/
but I don't know why I set the coordinate and assign the force
assigned beam's displacement is  lager than doesn't assigned beam
like this photo
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2018
    Hi,
    With Follower force, load follows the geometry as it deflects for this you need a coordinate system.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2018
    Really thanks to your reply
    but I still don't konw why we need to set coordinate to it
    and when we don't set coordinate means the analysis is wrong?
    thanks a lot
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2020
    Hi,
    Try this without coordinate system using FLLWER and FORCE1
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2018
    @Prakash Pagadala thanks to your apply
    and I use your model to set coordinate for case 1 and doesn't set for case 2
    at displacement result are the same. What are they mean
    <?xml version="1.0" encoding="UTF-8"?>1.thumb.jpg.0251b294a58db9a52c5ad181d1a21fef.jpg
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2018
    Hi,
    You dont need a system with the model I shared.
    The model I shared uses FLLWER card to tell the solver that the load applied (FORCE1) is a follower load.
Welcome!
Welcome!
