Incompatible extensions after update
User: "alireza_karbasi"
New Altair Community Member
Updated by Jocelyn
Hi,
After updating my Rapidminer to 7.3 version all of my extensions became unusable and I get this error that more than once incompatible extension is running, for example, I cannot add Tableau extension anymore. When I want to reinstall extension Rapidminer says they are already installed and up to date!
Thanks for your helps in advance.
1 - 16 of 161
    User: "Thomas_Ott"
    Are all your extensions up to date? The Tableau one is a bit funky because they generally makes it hard to integrate nicely with other software. It might require a re-install.
    OP
    Thanks for your answer
    Yes all of them are up to date, but still I cannot access to them
    User: "Thomas_Ott"
    When you installed RapidMiner, was it under the typical Program Files directory? Usually the extension are under your User/.RapidMiner directory and they are not affected by an upgrade, unless somehow the Studio installation is the in User directory.
    Also check under Extensions > Manage Extensions if they are all toggled on like so:
    OP
    Yes! Rapidminer is under typical program files in another drive and extensions are under Users somewhere else.
    So I have to uninstall Rapidminer and reinstall it in the same location as extensions or is there any other solution?
    User: "Thomas_Ott"
    No, the correct location for RapidMiner Studio is under your program files directory and the extensions under your /user/.RapidMiner folder.  What version of java are you running?
    OP
    Version 8
    User: "Thomas_Ott"
    That's odd, not sure what's going on because upgrades keep your user profile intact with your extensions.   Did you do anything else to your machine? was RapidMiner silently installed by your IT Admin?
    User: "IngoRM"
    Hi,
    If everything else fails, you could try to close RM and then delete the contents of
    <user_dir>/.RapidMiner/managed
    (make a backup first!) and then start RM again.  Your extensions should be gone now and you can re-install from the Marketplace.  Like Tom I have no idea what was actually causing this problem but at least I hope this will fix it.
    Hope this helps,
    Ingo
    OP
    Actually no, I did not do anything to my computer.
    I download new version
    OP
    I did the solution but still nothing change.
    As a matter of fact, except for the extensions, I have the error for other stuff too, which mentions other function may not work either. All of these happened after updating RM
    OP
    So there is nothing I can do to fix the problem?
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    you can post the contents of your rapidminer-studio.log file found in the USER/.RapidMiner folder after you started Studio and receive the dialog telling you about the extensions. There is probably a mixture of outdated .jar files being loaded which then break everything due to an error during the earlier update.
    If you don't want to wait for an answer based on the log though, you may also do the following easy fix:
    1. Close Studio
    2. Uninstall RapidMiner Studio and then delete the RapidMiner Studio installation folder if it is still there (make sure it's gone!)
    3. Go to USER/.RapidMiner and rename the "extensions" and "managed" folders (which effectively reset your available marketplace extensions)
    4. Install Studio 7.3 or even better, 7.4
    5. Install the extensions you want from the marketplace again.
    Doing the above does not touch your settings or data except removing all installed extensions, so it is safe to do as the installation folder of RapidMiner Studio does not contain any user-specific data, only the actual files contained in the installer.
    Regards,
    Marco
    OP
    Here is the content of the rapidminer-studio.log file after running it:
    Mar 09, 2017 9:29:09 AM com.rapidminer.tools.I18N <clinit>
    INFO: Set locale to en.
    Mar 09, 2017 9:29:09 AM com.rapidminer.core.license.ProductConstraintManager initialize
    INFO: Initializing license manager.
    INFO: Using default license location.
    INFO: Registering default product.
    Mar 09, 2017 9:29:10 AM com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: recommenders
    INFO: Register plugin: R Scripting
    INFO: Register plugin: Tableau Table Writer
    Mar 09, 2017 9:29:10 AM com.rapidminer.tools.plugin.Plugin resolveVersionConflict
    WARNING: Duplicate extension definition for extension rmx_h2o in D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\h2o-7.4.0-all.jar and D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\h2o-7.3.0-all.jar. Keeping extension with version 7.4.000.
    WARNING: Duplicate extension definition for extension rmx_advanced_file_connectors in D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-advanced-file-connectors-7.4.0-all.jar and D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-advanced-file-connectors-7.3.1-all.jar. Keeping extension with version 7.4.000.
    WARNING: Duplicate extension definition for extension rmx_concurrency in D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-concurrency-7.4.0-all.jar and D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-concurrency-7.3.1-all.jar. Keeping extension with version 7.4.000.
    WARNING: Duplicate extension definition for extension rmx_jdbc_connectors in D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-jdbc-connectors-7.4.0-all.jar and D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-jdbc-connectors-7.3.1-all.jar. Keeping extension with version 7.4.000.
    WARNING: Duplicate extension definition for extension rmx_legacy in D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-legacy-7.4.0-all.jar and D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-legacy-7.3.1-all.jar. Keeping extension with version 7.4.000.
    WARNING: Duplicate extension definition for extension rmx_productivity in D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-productivity-7.4.0-all.jar and D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-productivity-7.3.1-all.jar. Keeping extension with version 7.4.000.
    WARNING: Duplicate extension definition for extension rmx_professional in D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-professional-7.4.0-all.jar and D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-professional-7.3.1-all.jar. Keeping extension with version 7.4.000.
    WARNING: Duplicate extension definition for extension rmx_remote_repository in D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-remote-repository-7.4.0-all.jar and D:\Program Files\RapidMiner\RapidMiner Studio\lib\plugins\rapidminer-extension-remote-repository-7.3.1-all.jar. Keeping extension with version 7.4.000.
    Mar 09, 2017 9:29:11 AM com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: Cloud Connectivity
    INFO: Register plugin: Cloud Execution
    INFO: Register plugin: Data Editor
    INFO: Register plugin: H2O
    INFO: Register plugin: Operator Recommender
    INFO: Register plugin: Process Scheduling
    INFO: Register plugin: Advanced File Connectors
    INFO: Register plugin: Concurrency
    INFO: Register plugin: JDBC Connectors
    INFO: Register plugin: Legacy Result Access
    INFO: Register plugin: Productivity
    INFO: Register plugin: Professional
    INFO: Register plugin: Remote Repository
    INFO: Register plugin: Social Media
    Mar 09, 2017 9:29:11 AM com.rapidminer.tools.plugin.Plugin checkDependencies
    WARNING: Cannot register operators from Advanced File Connectors: RapidMiner Studio dependency not fulfilled! This extension needs RapidMiner Studio version 7.4.000. RapidMiner version is 7.3.001.
    WARNING: Cannot register operators from Concurrency: RapidMiner Studio dependency not fulfilled! This extension needs RapidMiner Studio version 7.4.000. RapidMiner version is 7.3.001.
    WARNING: Cannot register operators from H2O: RapidMiner Studio dependency not fulfilled! This extension needs RapidMiner Studio version 7.4.000. RapidMiner version is 7.3.001.
    WARNING: Cannot register operators from JDBC Connectors: RapidMiner Studio dependency not fulfilled! This extension needs RapidMiner Studio version 7.4.000. RapidMiner version is 7.3.001.
    WARNING: Cannot register operators from Legacy Result Access: RapidMiner Studio dependency not fulfilled! This extension needs RapidMiner Studio version 7.4.000. RapidMiner version is 7.3.001.
    WARNING: Cannot register operators from Productivity: RapidMiner Studio dependency not fulfilled! This extension needs RapidMiner Studio version 7.4.000. RapidMiner version is 7.3.001.
    WARNING: Cannot register operators from Professional: RapidMiner Studio dependency not fulfilled! This extension needs RapidMiner Studio version 7.4.000. RapidMiner version is 7.3.001.
    WARNING: Cannot register operators from R Scripting: Extension dependency not fulfilled! Missing extension rmx_professional with minimum version 7.2.0.
    WARNING: Cannot register operators from Remote Repository: RapidMiner Studio dependency not fulfilled! This extension needs RapidMiner Studio version 7.4.000. RapidMiner version is 7.3.001.
    WARNING: Cannot register operators from Social Media: Extension dependency not fulfilled! Missing extension rmx_professional with minimum version 7.3.0.
    WARNING: Cannot register operators from Tableau Table Writer: Extension dependency not fulfilled! Missing extension rmx_professional with minimum version 7.2.0.
    Mar 09, 2017 9:29:11 AM com.rapidminer.gui.renderer.RendererService init
    WARNING: Cannot initialize io object description: Cannot parse document: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Premature end of file.
    at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:257)
    at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:348)
    at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java:121)
    at com.rapidminer.gui.renderer.RendererService.init(RendererService.java:153)
    at com.rapidminer.gui.renderer.RendererService.init(RendererService.java:128)
    at com.rapidminer.tools.plugin.Plugin.registerDescriptions(Plugin.java:684)
    at com.rapidminer.tools.plugin.Plugin.registerAllPluginDescriptions(Plugin.java:901)
    at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:1308)
    at com.rapidminer.RapidMiner.init(RapidMiner.java:634)
    at com.rapidminer.RapidMiner.init(RapidMiner.java:573)
    at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:311)
    at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:775)
    at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:751)
    at com.rapidminer.launcher.GUILauncher.main(GUILauncher.java:334)
    WARNING: Cannot register operators from Cloud Connectivity: Extension dependency not fulfilled! Missing extension rmx_professional with minimum version 7.3.1.
    WARNING: Cannot register operators from Data Editor: Extension dependency not fulfilled! Missing extension rmx_professional with minimum version 7.3.0.
    WARNING: Cannot register operators from Operator Recommender: Extension dependency not fulfilled! Missing extension rmx_professional with minimum version 7.3.0.
    WARNING: Cannot register operators from Cloud Execution: Extension dependency not fulfilled! Missing extension rmx_remote_repository with minimum version 7.3.1.
    WARNING: Cannot register operators from Process Scheduling: Extension dependency not fulfilled! Missing extension rmx_remote_repository with minimum version 7.3.0.
    Mar 09, 2017 9:29:11 AM com.rapidminer.tools.plugin.Plugin initAll
    INFO: Extension rmx_tableau_table_writer could not be loaded successfully after 0ms.
    INFO: Extension rmx_concurrency could not be loaded successfully after 0ms.
    INFO: Extension rmx_productivity could not be loaded successfully after 0ms.
    INFO: Extension rmx_remote_repository could not be loaded successfully after 0ms.
    INFO: Extension rmx_h2o could not be loaded successfully after 0ms.
    INFO: Extension rmx_social_media could not be loaded successfully after 0ms.
    INFO: Extension rmx_jdbc_connectors could not be loaded successfully after 0ms.
    INFO: Extension rmx_r_scripting could not be loaded successfully after 0ms.
    INFO: Extension rmx_legacy could not be loaded successfully after 0ms.
    INFO: Extension rmx_professional could not be loaded successfully after 0ms.
    INFO: Extension rmx_advanced_file_connectors could not be loaded successfully after 0ms.
    INFO: Extension rmx_process_scheduling could not be loaded successfully after 6ms.
    INFO: Extension rmx_dataeditor could not be loaded successfully after 25ms.
    INFO: Extension rmx_operator_recommender could not be loaded successfully after 26ms.
    INFO: Extension rmx_cloud_execution could not be loaded successfully after 31ms.
    INFO: Extension recommenders was loaded in 113ms.
    INFO: Extension rmx_cloud_connectivity could not be loaded successfully after 612ms.
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    you indeed have a broken RapidMiner Studio installation, where multiple versions (7.3.1 and 7.4.0) conflict with each other. Please follow the steps I outlined above:
    1. Close Studio
    Regards,
    Marco
    OP
    Hi,
    In step 3, rename "extentions" and "managed" to what?
    User: "mmichel"
    Hey,
    just add the suffix "_old" ("extentions_old" and "managed_old") or whatever you prefer, so RapidMiner does not pick it up.
    Cheers,
    Marcel
