Martin is correct, you'd have to use a Multiply Data operator before the transformation and maybe a Generate ID operator so you can join the original and transformed data set back together via Join operator.
Hi,
there is no way to reverse this. This transformation is removing information. You might want to join the original data though.
~Martin
