🎉Community Raffle - Win $25
Join and Win
Word count in excell column
martin_redUser: "martin_red"
New Altair Community Member
Updated by Jocelyn
Hi All
I am trying to get a word count for words in a text column in excell data sheets.
I have used the following to create a word list
Read Excel -> Select Attributes -> Process documents from data
and tokenised the process docs data
This gives me a list of words and if they are used in the column as follows
Incident id    Password   Account   Reset   Computer  outlook   Crash
INC1           1                 1               1           0               0             0
INC2           0                 1               0           0               1             0
INC3           0                 0               0           1               0             1
However what i now need to get to is a count of the words as follows
Password         1
Account            2
Reset                1
Computer          1
Outlook             1
Crash                1
Whats the best way of returning these results?
This will allow me to quickly identify words used in the data that do not hoit the threashhold of number of times used. for example the data set i have has over 75000 different words used but i am only iterested in any word that has been used 25 times or more. i will then be able to add these words to the 'filter stopwords (dictonary)' easily
1 - 4 of 41
    In this case I would use an Aggregate operator instead of Process Documents for data. The Aggregate operator will take each column where your word is in the header and sum up all the 1's and 0's and give you the total.
    I am using the Process documents to break down the sentence though so
    password reset needed for account
    once run through the process doc with tokenize is then split down as
                    Password      Reset     Account
    INC1          1                    1            1
    When using the aggregate this just gives me
    a count of 'password reset needed for account ' as 1
    Thomas_OttUser: "Thomas_Ott"
    Accepted Answer
    I see. So then you should output the WOR port on the Process Documents from Data operator. That is the WordList port and it will give you a list of how many times the words occured.
    if you want to save this data back to Excel, then attache a WordList to data operator to the WOR output side and Write Excel.
    Thank you.
    I have been changing all sorts of operators etc and a very simple solution. failed to spot what the different out put does. will now look into these for other operators.
    Thanks again
