Sentiment Analysis using AYLIEN
mbinsaip
mbinsaip New Altair Community Member
edited November 2024 in Community Q&A
Hi,
I am new user of RapidMiner. I am interested to do research using twitter data for sentiment analysis. I follow tutorial from this link : http://blog.aylien.com/building-a-twitter-sentiment-analysis-process-in/
From my understanding, this process is using real time data from twitter. Does anyone know how to read data from database (e.g. excel, csv, SQLite) and apply  Sentiment Analysis from that data.
Thank for your help.
regards,
Saip
Welcome!
Best Answer
  • mbinsaip
    Answer ✓
    Hi,
    Thank you for informing me.
    Regards,
    Saip
Answers
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Dear Salip,
    simply replace the read Twitter operator with a Read Excel/CSV/Database operator. For databases you need to setup the connection in the Connections window.
    ~martin
  • mbinsaip
    Hi Martin,
    Thank you for your suggestion. It's work.
    Regards
    saip
  • mbinsaip
    Hi,
    Firt time run, it's work well.
    Second time run with the same dataset, no result (...??) in polarity, subjectivity, polarity_confidence and subjectivity_confidence.
    Any suggestions?
    regards,
    saip
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hey,
    the AYLIEN offering has 1000 calls per day for free. If you run more than these thousand it will add missings (?-signs).
    ~Martin
  • mbinsaip
    Answer ✓
    Hi,
    Regards,
    Saip
Welcome!
Welcome!
