1 - 2 of
21
Thanks for the reply. I see what you are saying however,the problem is that I cannot filter or use the total occurrences field. Sorting seems to be an unnecessary step since I need to filter the ones under certain threshold.
Sorting is also not working properly. There is nothing in populated in attribute list for sort operator but if I put total_occurrences, it works with a warning.
You should be able to review the output wordlist and identify the tokens you want to eliminate by sorting by total occurrences, and create a small text file with those words. Then you can use Filter Stopwords (dictionary) to suppress those tokens from your document processing.
