"CSV File too big to process?"
User: "eldenoso"
New Altair Community Member
Updated by Jocelyn
Hello altogether,
I have got a problem concerning the input data. I want to retrieve a 2GB CSV file, but everytime the operator stops at 40%, then the error message, that memory is not enough occurs (I have 16GB RAM). What can I do about that? Since Rapidminer is a data mining software I expected it to to things like that easily?
Thank you for your help :-)
1 - 4 of 41
    User: "Telcontar120"
    My first suggestion would be to try splitting your csv into smaller chunks (using any free utility like csv splitter) and then reading them in using a loop files operator and joining/appending them together.  I don't know how RapidMiner handles memory management for large files like that.  Perhaps one of the RM staffers will have another suggestion.
    User: "zprekopcsak"
    Hi,
    Can you share a data sample so we can investigate?
    Without not knowing anything about the data, I would have two suggestions to try:
    1. Make sure that the attribute types are properly set in the import wizard. If you store a datetime as a nominal instead of a proper datetime then you grow the memory footprint significantly. Same with attributes that have only missing values in the first X rows. RapidMiner will not be able to guess their types so unless you set that manually, it will default to nominal.
    2. You may want to try the in-product beta mode that has a lower memory footprint in general. See more details here: http://static.rapidminer.com/rnd/html/rapidminer-7.3-beta-mode.html
    Best,
    User: "eldenoso"
    OP
    The only idea I came up with (after searching the web) was import the CSV into an sql program (e.g. postgres), so that I can use the stream data operator?
    Unfortunately I cannot upload the data but I can tell you everything. It contains 8 attributes and round about 80 million examples. The only attribute I had to change with the import wizard was the date (it was set wrong). Ironically if I don't change the date-type the import succeeds.
    User: "Thomas_Ott"
    Sometimes dates are not read in correctly in the Read CSV operator, but that's OK. You can always convert those date values by using Nominal to Date operator.
