🎉Community Raffle - Win $25
Join and Win
Error Filter examples operator - parameter correct_predictions
User: "maed"
New Altair Community Member
Updated by Jocelyn
Hi
There's an error showing up when using "Filter examples" operator and choosing "correct_predictions" in parameters.
Am I doing something wrong or it's just a bug? Can I do this filtering in any other way?
Thank you in advance!
1 - 7 of 71
    Hi Maed,
    does your example set contain both a label and a prediction attribute with the corresponding role?
    ~Martin
    User: "edimala"
    Hi Martin
    My example set doesn't contain label attribute, only a prediction one applied by a model.
    So, I have an unlabeled dataset on which a model was applied. After the prediction, I wanted to filter only the examples predicted as true. It seems I cannot do it.
    Thanks
    User: "IngoRM"
    But "true" does not necessarily mean "correct" here... ;-)
    In order to use the filter correct predictions, you indeed need both a label attribute (containing the information what value actually is correct) plus a predicted label (which is compared against the true values in the label column).  If the label is missing, this particular filter option of course does not work then.
    What you are looking for is just a regular filter:
    1. Leave the condition class on "custom filter"
    2. Click on the "Filters..." button
    3. Select your prediction column on the left
    4. Select "equals" in the middle
    5. Select or enter "true" on the right
    The result will be all examples (i.e. rows) with a value of "true" in the prediction column.
    Hope this helps,
    Ingo
    User: "edimala"
    Hi Ingo
    Thank you for answering.
    In my case I have:
    1. An unlabeled dataset.
    2. The model (built elsewhere) is applied to the unlabeled dataset and the result is a new attribute is added to the dataset with the prediction.
    How can I have a label where my data is unlabeled? I already tried what you proposed but the prediction attribute doesn't show at all when inside the "custom filter".
    I am probably doing something wrong but I don't get it.
    User: "edimala"
    Hi Ingo
    Thank you for answering. I still have some issues...
    In my case I have:
    2. The model (built elsewhere) is applied to the unlabeled dataset and the result is a new attribute added to the dataset with the prediction.
    Thanks
    Edi
    User: "Telcontar120"
    Accepted Answer
    If you are using "Select attributes" anywhere in your process then you'll need to select the check box "include special attributes."  If you are using "Filter Examples" just try running the process once without the filter set to allow the metadata to propogate, and then your attribute should be avilable in the customer filter dropdown.  You might also want to check the "synchronize meta data with real data" option under the "process" menu at the top.  After that it should work as Ingo stated.  I tried it with one of my datasets and the prediction attribute shows up just fine.
    User: "maed"
    OP
    Accepted Answer
    Hi Brian
    I didn't have any "Select attributes" in the process but the "synchronize meta data with real data" did make the trick.
    Thanks a lot!
