Thanks again,
Unfortunately it is not working. while connecting Data to Documents to Write Document operator, it is giving an error message of wrong connection.
Try it with a Write CSV. That lets you write as TXT files too.
Why is this thread in the Developers forum?
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="social_media:search_twitter" compatibility="7.3.000" expanded="true" height="68" name="Search Twitter" width="90" x="45" y="34"> <parameter key="connection" value="ThomasOtt"/> <parameter key="query" value="RapidMiner"/> <parameter key="limit" value="10"/> </operator> <operator activated="true" class="extract_macro" compatibility="7.3.001" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="34"> <parameter key="macro" value="rows"/> <list key="additional_macros"/> </operator> <operator activated="true" class="loop" compatibility="7.3.001" expanded="true" height="82" name="Loop" width="90" x="313" y="34"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="%{rows}"/> <process expanded="true"> <operator activated="true" class="filter_example_range" compatibility="7.3.001" expanded="true" height="82" name="Filter Example Range" width="90" x="45" y="34"> <parameter key="first_example" value="%{iteration}"/> <parameter key="last_example" value="%{iteration}"/> </operator> <operator activated="true" class="select_attributes" compatibility="7.3.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Text"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="7.3.001" expanded="true" height="82" name="Nominal to Text" width="90" x="313" y="34"/> <operator activated="true" class="store" compatibility="7.3.001" expanded="true" height="68" name="Store" width="90" x="447" y="34"> <parameter key="repository_entry" value="data/%{rows}_row_data"/> </operator> <operator activated="true" class="write_csv" compatibility="7.3.001" expanded="true" height="82" name="Write CSV" width="90" x="581" y="34"> <parameter key="csv_file" value="C:\Users\ThomasOtt\Desktop\%{iteration}_row_data.txt"/> <parameter key="column_separator" value=","/> </operator> <connect from_port="input 1" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_op="Write CSV" to_port="input"/> <connect from_op="Write CSV" from_port="through" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Search Twitter" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
