ID column in K-means clustering
molsen
molsen New Altair Community Member
edited November 2024 in Community Q&A
Hello,
I am doing a text clustering on text by using K-means and the output goes to an Excel file.
All is working fine, but I can't seem to the original ID column into the new spreadsheet?
Instead a new column is created with ascending numbers.
This ID column: id column.JPGOriginal example set   Into this column:   excel.JPG
This is my workflow:
Welcome!
Best Answer
  • molsen
    Answer ✓
    I found a way to pass on the ID column on from the "Process Documents from Data" operator to the "K-means clustering" operator.
    It turned out that the only thing I had missed was a small checkmark called "Add meta information":
    After that I got the ID data all the way through to the Excel fil at the end!
Answers
  • Thomas_Ott
    Thomas_Ott New Altair Community Member
    Use a Set Role operator to set your ID column to the ID role. Then it should pass through to the clusters.
  • molsen
    Thank you for the reply, like this?
    Because it seems like the Id gets lost in the Process Documents, anything I have to do there?
  • Thomas_Ott
    Double check your process, I'm able to pass an attribute that's set with an ID role through Process Documents from Data.
    Which comes from this sumple Search Twitter Process.
    <?xml version="1.0" encoding="UTF-8"?><process version="7.3.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.3.000" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="social_media:search_twitter" compatibility="7.3.000" expanded="true" height="68" name="Search Twitter" width="90" x="112" y="34">
    <parameter key="connection" value="Twitter Connection"/>
    <parameter key="query" value="rapidminer"/>
    </operator>
    <operator activated="true" class="select_attributes" compatibility="7.3.000" expanded="true" height="82" name="Select Attributes" width="90" x="246" y="34">
    <parameter key="attribute_filter_type" value="subset"/>
    <parameter key="attributes" value="Id|Text"/>
    </operator>
    <operator activated="true" class="nominal_to_text" compatibility="7.3.000" expanded="true" height="82" name="Nominal to Text" width="90" x="380" y="34">
    <parameter key="attribute_filter_type" value="single"/>
    <parameter key="attribute" value="Text"/>
    </operator>
    <operator activated="true" class="text:process_document_from_data" compatibility="7.2.001" expanded="true" height="82" name="Process Documents from Data" width="90" x="514" y="34">
    <list key="specify_weights"/>
    <operator activated="true" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Tokenize" width="90" x="246" y="34"/>
    <connect from_port="document" to_op="Tokenize" to_port="document"/>
    <connect from_op="Tokenize" from_port="document" to_port="document 1"/>
    <portSpacing port="source_document" spacing="0"/>
    <portSpacing port="sink_document 1" spacing="0"/>
    <portSpacing port="sink_document 2" spacing="0"/>
    </process>
    </operator>
    <connect from_op="Search Twitter" from_port="output" to_op="Select Attributes" to_port="example set input"/>
    <connect from_op="Select Attributes" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/>
    <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
    <connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/>
    </process>
    </operator>
    </process>
  • molsen
    Danm, I'm not able to make it work Mr. T-Bone!
    Can you share your workflow?
    Or do you know of a guide that shows how to pass the ID through?
    I have made mine based on this tutorial:
    k-means clustering tutorial
  • molsen
    Answer ✓
Welcome!
Welcome!
