Altair RISE
Nominate Yourself Now!
Text mining in utf-8
User: "i_anicka"
New Altair Community Member
Updated by Jocelyn
Hello all,
I need to use RapidMiner for text mining in Cyrilic.
I tried setting the encoding to utf-8. It gives me some results which are displayed in characters instead of cyrilic words.
Thanks,
1 - 9 of 91
    Hi,
    could you maybe post an example?
    ~Martin
    User: "JEdward"
    It could be that your original document isn't in UTF-8, but in another encoding.
    One way to be absolutely sure is to create a loop which changes the encoding parameter in your process documents using macros and to look at all the resulting outputs.  The one that looks 'right'.
    User: "sgenzer"
    Altair Employee
    agreed.  Just did a quick check and there's no problem with Cyrillic in UTF-8.
    <?xml version="1.0" encoding="UTF-8"?><process version="7.3.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.3.000" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="text:create_document" compatibility="7.3.000" expanded="true" height="68" name="Create Document" width="90" x="45" y="34">
    <parameter key="text" value="Для поиска нажмите Ввод"/>
    </operator>
    <operator activated="true" class="text:documents_to_data" compatibility="7.3.000" expanded="true" height="82" name="Documents to Data" width="90" x="179" y="34">
    <parameter key="text_attribute" value="text"/>
    </operator>
    <connect from_op="Create Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/>
    <connect from_op="Documents to Data" from_port="example set" to_port="result 1"/>
    </process>
    </operator>
    </process>
    Scott
    User: "i_anicka"
    OP
    Accepted Answer
    Hi guys,
    I have solved my problem.
    I had set the utf-8 encoding everywhere except on the process level.
    I changed this and it works!
    Thank you all for your replies.
    Ana,
    User: "arunasethupathy"
    I want to use Tamil language for text mining
    Where you have change the UTF-8 option for this
    I have tried in process level but unable to get
    Plz anybody give the answer
    for changing the unicode option to UTF-8 ( for processing tamil language)
    I have changed in the Rapidminer studio preference - encoding to UTF-8
    I have simply read the document using ReadDocument operator in Text mining extension
    But it is not working, the screen shot is attached ( doc7.docx)
    Kindly help me to sort out this problem
    Tahnk you
    User: "sgenzer"
    Altair Employee
    Hello @arunasethupathy - so Tamil is not a language I have worked with before.  Could you please post your XML process AND your text document (in Tamil) so I can take a look?
    Thank you.
    Scott
    Sir,
    Kindly find the attached for the sample tamil text document
    User: "sgenzer"
    Altair Employee
    thank you @arunasethupathy.  Can you please also post your XML process?
    Scott
