./gradlew initializeExtensionProject ERROR
hi,
I followed the "How to extend Rapidminer 7" tutorial pdf on to the point with the command ./gradlew initializeExtensionProject
I get an error:
FAILURE: Build failed with an exception.
* What went wrong:
Task 'initializeExtensionProject' not found in root project 'rapidminer-extension-template-master'.
* Try:
Run gradlew tasks to get a list of available tasks. Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
what am I doing wrong? I imported the rapidminer-extension-template into the workspace...
my workspace is still missing src/main/java and several other folders...
- Download the extension template.
- Unzip the archive.
- Open your preferred console (you should not use the IDE at this point)
- Goto the root directory and update the build.gradle file accordingly (e.g. change the extension name)
- From the root directory call one of the following commands:
- Linux/ OSX:
- Windows:
gradlew.bat initializeExtensionProject
- Linux/ OSX:
- Verify the properties and confirm the generation.
- Open the initialzed extension project with your IDE and start coding.
gradle.properties file shows its version = 1.0.0
after I executed your command and the one in the manual, it gives an error:
PS C:\Users\x\workspace\rapidminer-extension-template-master> ./gradlew --refresh-dependencies iEP
:ideaProject
BUILD SUCCESSFUL
Total time: 50.354 secs
PS C:\Users\x\workspace\rapidminer-extension-template-master> ./gradlew initializeExtensionProject
* What went wrong:
* Try:
or -
-debug
BUILD FAILED
Hi Fred,
the gradle.properties contains only the version of your extension. So please open the build.gradle file and check for the following line:
plugins { id 'com.rapidminer.extension' version '0.8.2' }
It's a little bit strange that the result of the
command isnot the same, because iEP should be mapped to initializeExtensionProject.
What happens if you execute the batch file?
I get another error:
* What went wrong:
* Try:
or -
-debug
BUILD FAILED
Total time: 3.82 secs
I have 0.8.2:
maybe they changed something in their packages and files are missing?
Hi Fred,
maybe it's a caching issue.
The 'rapidminer-extension-template-master' folder should contain a hidden '.gradle' folder (notice the DOT). Please delete it. The folder will be recreated every time you run a gradle task.
After you've removed the folder try to execute the
./gradlew tasks
command to retrieve the list of the available gradle tasks. If initializeExtensionProject is listed we are fine and you can try to execute the task, otherwise we need to come up with a different solution (in this case please post the ouput of the previous command).
Cheers,
Marcel
C:\Users\x\workspace\rapidminer-extension-template-master>gradlew tasks
:tasks
All tasks runnable from root project
Default tasks: installExtension
Build tasks
assemble - Assembles the outputs of this project.
build - Assembles and tests this project.
buildDependents - Assembles and tests this project and all projects that depend on it.
buildNeeded - Assembles and tests this project and all projects it depends on.
classes - Assembles classes 'main'.
clean - Deletes the build directory.
externalClasses - Assembles classes 'external'.
jar - Assembles a jar archive containing the main classes.
testClasses - Assembles classes 'test'.
Build Setup tasks
init - Initializes a new Gradle build. [incubating]
Documentation tasks
javadoc - Generates Javadoc API documentation for the main source code.
Help tasks
components - Displays the components produced by root project 'rapidminer-extension-template-master'. [incubating]
dependencies - Displays all dependencies declared in root project 'rapidminer-extension-template-master'.
dependencyInsight - Displays the insight into a specific dependency in root project 'rapidminer-extension-template-master'.
help - Displays a help message.
model - Displays the configuration model of root project 'rapidminer-extension-template-master'. [incubating]
projects - Displays the sub-projects of root project 'rapidminer-extension-template-master'.
properties - Displays the properties of root project 'rapidminer-extension-template-master'.
tasks - Displays the tasks runnable from root project 'rapidminer-extension-template-master'.
IDE tasks
cleanEclipse - Cleans all Eclipse files.
cleanIdea - Cleans IDEA project files (IML, IPR)
eclipse - Generates all Eclipse files.
idea - Generates IDEA project files (IML, IPR, IWS)
Publishing tasks
generatePomFileForJarPublication - Generates the Maven POM file for publication 'jar'.
publish - Publishes all publications produced by this project.
publishJarPublicationToMavenLocal - Publishes Maven publication 'jar' to the local Maven repository.
publishJarPublicationToMavenRepository - Publishes Maven publication 'jar' to Maven repository 'Maven'.
publishToMavenLocal - Publishes all Maven publications produced by this project to the local Maven cache.
RapidMiner Code Quality tasks
checkstyleInitDefaultConfig - Copies the default checkstyle.xml files to the configured configuration directory.
eclipseCheckstyle - Creates Checkstyle Eclipse plugin config files for the current project.
eclipseFindBugs - Creates FindBugs Eclipse plugin config files for the current project.
RapidMiner Extension tasks
installExtension - Create a jar bundled with all dependencies and copies the jar to the configured 'extensionFolder'. By default the extension is copied to '~/.RapidMiner/extensions'.
Shadow tasks
knows - Do you know who knows?
shadowJar - Create a combined JAR of project and runtime dependencies
Verification tasks
check - Runs all checks.
test - Runs the unit tests.
Other tasks
checkstyleExternalHTMLReport - Task that generates a HTML report from the checkstyle task result
checkstyleMainHTMLReport - Task that generates a HTML report from the checkstyle task result
checkstyleTestHTMLReport - Task that generates a HTML report from the checkstyle task result
cleanIdeaWorkspace
downloadLicenses
findbugsExternal - Run FindBugs analysis for external classes
findbugsTest - Run FindBugs analysis for test classes
javadocJar
license
licenseFormat
sourceJar
testJar
wrapper - Adds/Updates the Gradle wrapper.
Rules
Pattern: clean<TaskName>: Cleans the output files of a task.
Pattern: build<ConfigurationName>: Assembles the artifacts of a configuration.
Pattern: upload<ConfigurationName>: Assembles and uploads the artifacts belonging to a configuration.
To see all tasks and more detail, run gradlew tasks --all
To see more detail about a task, run gradlew help --task <task>
BUILD SUCCESSFUL
Total time: 11.37 secs
C:\Users\x\workspace\rapidminer-extension-template-master>gradlew initializeExtensionProject
* What went wrong:
* Try:
BUILD FAILED
Total time: 3.584 secs
did not help in any way...
Hi Fred,
this is very weird...
Please try to update the gradle extension plugin:
Open the build.gradle file in the rapidminer-extension-template-master project and update the following line.
Change this
plugins { id 'com.rapidminer.extension' version '0.8.2'}
to this
plugins { id 'com.rapidminer.extension' version '0.9.1' }
and run the
gradlew tasks
again.
The initializeExtensionTask is only available if the 'PluginInit*.java' was not created. So make sure the file does not exist or download and create a new empty project.
It already solved. I try to re unzip the file (rapidminer template master) and run it (initializeExtensionProject) from eclipse, it gave me an error. Then I try to re unzip again and run it from command and it run well, after that I try to re unzip again and run it from eclipse, it run well too. I don't now what's wrong, but it solve my problem.
Hi wassdullull,
by following this short list you should be able to initialize the extension:
If the described approach is still not working please provide more details - like the OS you are currently using and the exact error message.
Hope this helps,
Marcel
Hi Fred,
which version of the 'com.rapidminer.extension' gradle plugin are you using? Version 0.8.2. should include the task.
The plugins and versions are defined in the build.gradle file.
Cheers,
Marcel
