How to specify time varying moment in hypermesh?
Hello!!
I am doing dynamic analysis of vibration measurement test rig for single cylinder engine assembly. I have specified time varying force using DAREA , TABLED1 & TLOAD1. I want to know how to specify time varying moment of large time history (90 seconds, 0.0003125 s-increment).
Thanks & Regards
Ramsubramanian P
In same way, DAREA(Rotational dof activated) can be referenced as excitation load in TLOAD1 to specify time varying moment????
Hi,
yes you can give DAREA in TLOAD1. Are you performing any rotar dynamic simulation?
I have tried DAREA(Rotational dof activated) to define time varying moment,but it failed.But if I changed DAREA(translation dof activated) ,it worked out! I mean DAREA can only be defined as force instead of moment.
Hi RamSubramanian,
You can reference MOMENT load in RLOAD1 as excitation load.
Please refer to RLOAD1 card in help for more information.
