How to specify time varying moment in hypermesh?
Hello!!
I am doing dynamic analysis of vibration measurement test rig for single cylinder engine assembly. I have specified time varying force using DAREA , TABLED1 & TLOAD1. I want to know how to specify time varying moment of large time history (90 seconds, 0.0003125 s-increment).
Thanks & Regards
Ramsubramanian P
Answers
Thanks a lot sir
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
0 -
In same way, DAREA(Rotational dof activated) can be referenced as excitation load in TLOAD1 to specify time varying moment????
0 -
Hi,
yes you can give DAREA in TLOAD1. Are you performing any rotar dynamic simulation?
0 -
Thanks sir.
No. I am doing dynamic analysis of vibration measurement test rig for single cylinder engine assembly. I am going to apply the reciprocating imbalance forces & moments at the crank bearing and going to find acceleration response at the crankcase.
Regards
Ramsubramanian
0 -
Altair Forum User said:Hi,
I have tried DAREA(Rotational dof activated) to define time varying moment,but it failed.But if I changed DAREA(translation dof activated) ,it worked out! I mean DAREA can only be defined as force instead of moment.
0 -
Hi HuangZhou,
You can directly refer MOMENT or FORCE in TLOAD1 card. Refer to the attached snapshot from help.
Thanks for your reply! That is truely what I want to emphasize! I have used the same way as you said, and the result is the same compared with result I get from patran/nastran.
0 -
Well, I will also call MOMENT into RLOAD2.....Thanks....
0 -
Yes, MOMENT can be used as excited in TLOAD# and RLOAD#
0
