ok thanks, saving in repository works, but is there any way to retrieve the image from repository into rapidminer? or is there some image format that can be recognized by rapidminer so you can catch the image from the repository?
Hi,
under File -> Print/Export Images -> Export Image you save the summary window in a number of different formats.
Best,
David
