🎉Community Raffle - Win $25
Join and Win
Loop Files Operator
User: "7amritaarora7"
New Altair Community Member
Updated by Jocelyn
How can we transfer data from loop files operator to data to documents operator?
- The nested processes in loop files operator are working fine
- When I connect it to documents to data, I can't select text attribute in its properties, there isn't any option in the dropdown
- Similarly, I can't set role label
Need urgent Help
P.S. - I'm trying out the process mentioned in Chapter 14 of the book - RapidMiner - Data Mining Use Cases and Business Analytics Applications by CRC Press, edited by Markus Hofmann and Ralf Klinkenberg
1 - 5 of 51
    Hi,
    have you tried to use an append operator?
    Otherwise could you maybe post your process please?
    ~Martin
    OP
    Hi
    I'm attaching the process here, please have a look
    Amrita
    OP
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hey,
    what defintly works, but is maybe not the most elegant solution, is using a Loop collection. Attached is a process showing it.
    ~Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="7.2.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.2.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="loop" compatibility="7.2.001" expanded="true" height="82" name="Loop" width="90" x="112" y="34">
    <parameter key="set_iteration_macro" value="true"/>
    <operator activated="true" class="text:create_document" compatibility="7.2.000" expanded="true" height="68" name="Create Document" width="90" x="246" y="85">
    <parameter key="text" value="abc %{iteration}"/>
    </operator>
    <connect from_op="Create Document" from_port="output" to_port="output 1"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    </operator>
    <operator activated="true" class="loop_collection" compatibility="7.2.001" expanded="true" height="82" name="Loop Collection" width="90" x="246" y="34">
    <operator activated="true" class="text:documents_to_data" compatibility="7.2.000" expanded="true" height="82" name="Documents to Data" width="90" x="112" y="34">
    <parameter key="text_attribute" value="text"/>
    </operator>
    <connect from_port="single" to_op="Documents to Data" to_port="documents 1"/>
    <connect from_op="Documents to Data" from_port="example set" to_port="output 1"/>
    <portSpacing port="source_single" spacing="0"/>
    </process>
    </operator>
    <operator activated="true" class="append" compatibility="7.2.001" expanded="true" height="82" name="Append" width="90" x="380" y="34"/>
    <connect from_op="Loop" from_port="output 1" to_op="Loop Collection" to_port="collection"/>
    <connect from_op="Loop Collection" from_port="output 1" to_op="Append" to_port="example set 1"/>
    <connect from_op="Append" from_port="merged set" to_port="result 1"/>
    </process>
    </operator>
    </process>
    OP
    Hey Martin
    Thanks a lot! :)
    Will add it to the process, hopefully no other issues arise.
    Regards
    Amrita
