Loop Files Operator
How can we transfer data from loop files operator to data to documents operator?
- The nested processes in loop files operator are working fine
- When I connect it to documents to data, I can't select text attribute in its properties, there isn't any option in the dropdown
- Similarly, I can't set role label
Need urgent Help
P.S. - I'm trying out the process mentioned in Chapter 14 of the book - RapidMiner - Data Mining Use Cases and Business Analytics Applications by CRC Press, edited by Markus Hofmann and Ralf Klinkenberg
@mschmitz any solution?
Hey,
what defintly works, but is maybe not the most elegant solution, is using a Loop collection. Attached is a process showing it.
~Martin
<?xml version="1.0" encoding="UTF-8"?><process version="7.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.2.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="loop" compatibility="7.2.001" expanded="true" height="82" name="Loop" width="90" x="112" y="34">
<parameter key="set_iteration_macro" value="true"/>
<operator activated="true" class="text:create_document" compatibility="7.2.000" expanded="true" height="68" name="Create Document" width="90" x="246" y="85">
<parameter key="text" value="abc %{iteration}"/>
</operator>
<connect from_op="Create Document" from_port="output" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="loop_collection" compatibility="7.2.001" expanded="true" height="82" name="Loop Collection" width="90" x="246" y="34">
<operator activated="true" class="text:documents_to_data" compatibility="7.2.000" expanded="true" height="82" name="Documents to Data" width="90" x="112" y="34">
<parameter key="text_attribute" value="text"/>
</operator>
<connect from_port="single" to_op="Documents to Data" to_port="documents 1"/>
<connect from_op="Documents to Data" from_port="example set" to_port="output 1"/>
<portSpacing port="source_single" spacing="0"/>
</process>
</operator>
<operator activated="true" class="append" compatibility="7.2.001" expanded="true" height="82" name="Append" width="90" x="380" y="34"/>
<connect from_op="Loop" from_port="output 1" to_op="Loop Collection" to_port="collection"/>
<connect from_op="Loop Collection" from_port="output 1" to_op="Append" to_port="example set 1"/>
<connect from_op="Append" from_port="merged set" to_port="result 1"/>
</process>
</operator>
</process>
Hey,
~Martin
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</process>
</operator>
</operator>
</process>
</operator>
</process>
</operator>
</process>
Hi,
have you tried to use an append operator?
Otherwise could you maybe post your process please?
~Martin
