🎉Community Raffle - Win $25
Join and Win
how to know if a macro exists in `execute R`?
jujuUser: "juju"
New Altair Community Member
Updated by Jocelyn
Hi the content is this:
- need to pass values as macros, since that seems to be the only way for web service
- use `execute R` to parse the macros, since it's more flexible to handle strings and lots of if...then...
First question is how to refer to macro in `execute R`. I did some tests and figured it out myself:
Suppose you set macro m1 to be x, then whenever your write %{m1} in `execute R`, the software will just literally replace %{m1} with x
For example:
rm_main = function()
x = 3
z = %{m1} # interpreted as z = x
print(z) # 3
xy = 3
z = %{m1}y # interpreted as z = xy
print(z) # 3
If want to pass a string 'x', either set macro m1 to be 'x',
or do z = '%{m1}' in `execute R`.
Now the second question is, if some macros are optional, how to test if they exist in `execute R`?
One solution is, fix it at the web service side - Always set macro to be NA if it's not used.
But can we handle omitted macro in `exexute R`? (So that the web service side can pass as many macros as they want)
This doesn't seem to work
exists('%{m1}')  # interpreted as exists('x'), can't test if the macro exists
Use `try`
try( z <- '%{m1}' )
print(exists('z'))
when there's no macro m1, it stills throws error (even when using `try`)
How do I test the existance of a macro?
Any help's appreciated. Thank you~
1 - 3 of 31
    Hi,
    what about defining them in the context with a default value of -1 or something. You can test in R on if (%{myMacro!=-1) or something
    Edit: Another option would be to do the handling in RM using either Branch or Handle Exception.
    ~Martin
     Hi,
    just to add some details:
    The reason why you get an exception in the R script is because macros are always evaluated first and the results are then applied by the corresponding Operator.
    Otherwise Martin's suggesting should work perfectly.
    jujuUser: "juju"
    OP
    nice trick! Thanks Martin
