🎉Community Raffle - Win $25
Join and Win
Filtering with whitespace regex not working
User: "AK"
New Altair Community Member
Updated by Jocelyn
I have nominal attributes Entity and EntityType. Entity contains a number of names of people and organizations. EntityType contains which type the Entity is (Organization or Person). I am trying to filter on EntityType == Person where Entity contains a full name. I want to omit single names.
I am using Filter Examples with attribute_value_filter. The string parameter is set as below.
EntityType = PERSON && Entity = [a-zA-Z]*\s.*
This does not select any of the names. I think I have isolated the issue to the whitespace character class within Entity. Any filtering on whitespace fails. For example, all of the below parameters failed to catch Bart Simpson.
Entity = Bart\sSimpson
Entity = Bart[ ]Simpson
Entity = Bart Simpson
However, the below worked.
Entity = Bart.+Simpson
Any ideas on how to match full names?
Below is an example of how I want my filter to work.
Input
Entity EntityType
Fox Network ORGANIZATION
Homer J. Simpson PERSON
Homer PERSON
Marge PERSON
Bart Simpson PERSON
Lisa Simpson PERSON
Desired Output
Entity EntityType
Bart Simpson PERSON
Lisa Simpson PERSON
