How to configure Server version with Studio version
I just updated our RM server to version 7.1 with “rapidminer-server-installer-7.1.0”, and restarted the server. When I try to connect from RM studio (7.1.1), it says the server version is 7.0 and can’t connect. What could be the problem here. Is there a way to check the version of server installed on command line or remove previous JAR files?
Thanks,
Craig
Hi Craig,
had you have a look on the documentation? http://docs.rapidminer.com/server/installation/upgrading-server.html
~Martin
good 7.2 Server set up Video
Hello @CraigBostonUSA ,
not sure what could have gone wrong, but did u run the complete installer,
if you pointed to installtion to same folder as your previous server location, then typically a common issue is you may not have removed the old files before runing the new installer
We recommend to not do a full installation into an existing RapidMiner Server folder but rather to use a fresh folder. However, if you do chose to overwrite an existing installation, please remove all files in thestandalone/deployments
folder that either start with rapidminer-server-*
or ROOT.war
. Failure to do so might result in RapidMiner Server not being able to start correctly.
you can see more details here
http://docs.rapidminer.com/server/administration/maintenance/updating-rms.html#full-upgrade
My quick solution will be stop the previous server from service panel and install at a fresh location as we recommend
Hi Craig,
~Martin
folder that either start withrapidminer-server-*
orROOT.war
. Failure to do so might result in RapidMiner Server not being able to start correctly.you can see more details here
