🎉Community Raffle - Win $25
Join and Win
subsetting in execute R process
jujuUser: "juju"
New Altair Community Member
Updated by Jocelyn
Hi, some basic subsetting of data frame seems to be not working when executing R in Rapidminer.
I ran this R code in Rstudio and it yields correct dimension after subsetting:
cat('dimension of training x:', dim(as.data.frame(dat[train, x])), '\n')
cat('dimension of training y:', dim(as.data.frame(dat[train, y])), '\n')
# dimension of training x: 138 60
# dimension of training y: 138 1
And then I paste this R code into a execute R process in Rapidminer, and it yields:
Jul 7, 2016 4:57:43 PM INFO: dimension of training x: 62 1
Jul 7, 2016 4:57:43 PM INFO: dimension of training y: 62 1
I print many other things to debug, and other things are all same in two cases (Rstudio vs Rapidminer). -- See complete output below
Sonar data (208 rows * 61 columns) is used in both cases.
Complete R code:
library(mlbench)
rm_main = function(dat, in_rapidminer = T){
cat('Starting R script now ...\n')
# find columns of x (attribute) and y (response) ####
if(in_rapidminer){
meta = melt(metaData)
meta$L1 = NULL
names(meta) = c('value', 'variable', 'column')
meta = dcast(meta, formula = column ~ variable)
print(meta)
y_name = meta[meta$role %in% 'label', 'column']
x_name = meta[meta$role %in% 'attribute', 'column']
y = names(dat) %in% y_name
x = names(dat) %in% x_name
} else {
# in R manually specify it:
y_name = 'Class'
x = ! names(dat) %in% c(y_name, 'pred_prob', 'pred')
cat('y column:', which(y), '\n')
cat('x column(s):', which(x), '\n')
cat('dimension of data:', dim(dat), '\n')
# encode y (only work for binary) ####
f1 = paste0('~', y_name, '- 1')
dat[[y_name]] = model.matrix(as.formula(f1), data = dat)[ , 1]
n_row = nrow(dat)
n_fold = 3
set.seed(123)
group = (seq_len(n_row) - 1) %% n_fold + 1
group = sample(group) # random permutation
print(table(group))
# n_fold CV ####
for(ii in seq_len(n_fold)){
cat('CV round', ii, '\n')
train = group != ii
cat('how many rows in training set:', sum(train), '\n')
return(1)
data(Sonar)
dat = Sonar
rm_main(dat, in_rapidminer = F)
Complete output:
y column: 61
x column(s): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
dimension of data: 208 61
group
1 2 3
70 69 69
CV round 1
how many rows in training set: 138
CV round 2
how many rows in training set: 139
dimension of training x: 139 60
dimension of training y: 139 1
CV round 3
(Highlight in red by me)
Complete Rapidminer code:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="6.4.000">
<context>
<input>
<location>//_your_path_/Sonar</location>
</input>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="multiply" compatibility="6.4.000" expanded="true" height="94" name="Multiply" width="90" x="112" y="120"/>
<operator activated="true" class="r_scripting:execute_r" compatibility="6.4.000" expanded="true" height="76" name="CV" width="90" x="313" y="165">
<parameter key="script" value="rm_main = function(dat, in_rapidminer = T){&#10; &#10; cat('Starting R script now ...\n')&#10; &#10;&#10; # find columns of x (attribute) and y (response) ####&#10; if(in_rapidminer){&#10; meta = melt(metaData)&#10; meta$L1 = NULL&#10; names(meta) = c('value', 'variable', 'column')&#10; &#10; meta = dcast(meta, formula = column ~ variable)&#10; print(meta)&#10; &#10; y_name = meta[meta$role %in% 'label', 'column']&#10; x_name = meta[meta$role %in% 'attribute', 'column']&#10; &#10; y = names(dat) %in% y_name&#10; x = names(dat) %in% x_name&#10; } else {&#10; # in R manually specify it:&#10; y_name = 'Class'&#10; y = names(dat) %in% y_name&#10; x = ! names(dat) %in% c(y_name, 'pred_prob', 'pred')&#10; }&#10; &#10; cat('y column:', which(y), '\n')&#10; cat('x column(s):', which(x), '\n')&#10; &#10; cat('dimension of data:', dim(dat), '\n')&#10; &#10; &#10; # encode y (only work for binary) ####&#10; f1 = paste0('~', y_name, '- 1')&#10; dat[[y_name]] = model.matrix(as.formula(f1), data = dat)[ , 1]&#10; &#10; &#10; # ####&#10; n_row = nrow(dat)&#10; n_fold = 3&#10; &#10; set.seed(123)&#10; &#10; group = (seq_len(n_row) - 1) %% n_fold + 1&#10; group = sample(group) # random permutation&#10; print(table(group))&#10; &#10; # n_fold CV ####&#10; for(ii in seq_len(n_fold)){&#10; &#10; cat('CV round', ii, '\n')&#10; train = group != ii&#10; cat('dimension of data:', dim(dat), '\n')&#10; cat('how many rows in training set:', sum(train), '\n')&#10; &#10; cat('dimension of training x:', dim(as.data.frame(dat[train, x])), '\n')&#10; cat('dimension of training y:', dim(as.data.frame(dat[train, y])), '\n')&#10;&#10; }&#10; &#10; return(1)&#10;}"/>
</operator>
<connect from_port="input 1" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_port="result 1"/>
<connect from_op="Multiply" from_port="output 2" to_op="CV" to_port="input 1"/>
<connect from_op="CV" from_port="output 1" to_port="result 2"/>
<portSpacing port="source_input 1" spacing="90"/>
<portSpacing port="source_input 2" spacing="0"/>
<portSpacing port="sink_result 3" spacing="0"/>
<description align="center" color="yellow" colored="false" height="58" resized="true" width="214" x="250" y="243">This R code works with binary (two-class) response only</description>
</process>
</operator>
</process>
Complete log in Rapidminer:
Jul 7, 2016 5:15:25 PM INFO: Starting R script now ...
Jul 7, 2016 5:15:25 PM INFO: column role type
Jul 7, 2016 5:15:25 PM INFO: 1 attribute_1 attribute real
Jul 7, 2016 5:15:25 PM INFO: 2 attribute_10 attribute real
Jul 7, 2016 5:15:25 PM INFO: 3 attribute_11 attribute real
<I omit some lines here for clarity>
Jul 7, 2016 5:15:25 PM INFO: 58 attribute_7 attribute real
Jul 7, 2016 5:15:25 PM INFO: 59 attribute_8 attribute real
Jul 7, 2016 5:15:25 PM INFO: 60 attribute_9 attribute real
Jul 7, 2016 5:15:25 PM INFO: 61 class label nominal
Jul 7, 2016 5:15:25 PM INFO: y column: 61
Jul 7, 2016 5:15:25 PM INFO: x column(s): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
Jul 7, 2016 5:15:25 PM INFO: dimension of data: 208 61
Jul 7, 2016 5:15:25 PM INFO: group
Jul 7, 2016 5:15:25 PM INFO: 1 2 3
Jul 7, 2016 5:15:25 PM INFO: 70 69 69
Jul 7, 2016 5:15:25 PM INFO: CV round 1
Jul 7, 2016 5:15:25 PM INFO: how many rows in training set: 138
Jul 7, 2016 5:15:25 PM INFO: dimension of training x: 61 1
Jul 7, 2016 5:15:25 PM INFO: dimension of training y: 61 1
Jul 7, 2016 5:15:25 PM INFO: CV round 2
Jul 7, 2016 5:15:25 PM INFO: how many rows in training set: 139
Jul 7, 2016 5:15:25 PM INFO: CV round 3
Jul 7, 2016 5:15:25 PM INFO: Saving results.
Jul 7, 2016 5:15:25 PM INFO: Process
Any help's appreciated. Thanks-
1 - 7 of 71
    jujuUser: "juju"
    OP
    <I deleted this reply>
    Andrew2User: "Andrew2"
    Hello
    What is the variable metaData in the R script. If you do str(metaData) what do you get?
    regards
    Andrew
    jujuUser: "juju"
    OP
    Thanks Andrew. metaData is a list of list of list.
    (In case you're not familiar with metaData, it's information about the role (label/id/attribute/...) and the datatype of each column. For example, you can use `set role` operator in Rapidminer to control the role, and you can control the role in import data wizard.)
    The official doc of `execute R` operator talks about handling metadata <http://docs.rapidminer.com/studio/operators/utility/scripting/execute_r.html>
    if you go to the HELP of `execute R` in Rapidminer, there're links to the examples in the doc.
    Jul 7, 2016 10:39:36 PM INFO: List of 1
    Jul 7, 2016 10:39:36 PM INFO: $ dat:List of 61
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_1 :List of 2
    Jul 7, 2016 10:39:36 PM INFO: .. ..$ type: chr "real"
    Jul 7, 2016 10:39:36 PM INFO: .. ..$ role: chr "attribute"
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_2 :List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_3 :List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_4 :List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_5 :List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_6 :List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_7 :List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_8 :List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_9 :List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_10:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_11:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_12:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_13:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_14:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_15:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_16:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_17:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_18:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_19:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_20:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_21:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_22:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_23:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_24:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_25:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_26:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_27:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_28:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_29:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_30:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_31:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_32:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_33:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_34:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_35:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_36:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_37:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_38:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_39:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_40:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_41:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_42:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_43:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_44:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_45:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_46:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_47:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_48:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_49:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_50:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_51:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_52:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_53:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_54:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_55:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_56:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_57:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_58:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_59:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ attribute_60:List of 2
    Jul 7, 2016 10:39:36 PM INFO: ..$ class :List of 2
    Jul 7, 2016 10:39:36 PM INFO: .. ..$ type: chr "nominal"
    Jul 7, 2016 10:39:36 PM INFO: .. ..$ role: chr "label"
    Jul 7, 2016 10:39:36 PM INFO: NULL
    It's easier to see after flattening and reorganization:
    Jul 7, 2016 10:39:36 PM INFO: meta data reorganized:
    Jul 7, 2016 10:39:36 PM INFO: column role type
    Jul 7, 2016 10:39:36 PM INFO: 1 attribute_1 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 2 attribute_10 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 3 attribute_11 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 4 attribute_12 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 5 attribute_13 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 6 attribute_14 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 7 attribute_15 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 8 attribute_16 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 9 attribute_17 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 10 attribute_18 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 11 attribute_19 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 12 attribute_2 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 13 attribute_20 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 14 attribute_21 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 15 attribute_22 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 16 attribute_23 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 17 attribute_24 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 18 attribute_25 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 19 attribute_26 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 20 attribute_27 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 21 attribute_28 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 22 attribute_29 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 23 attribute_3 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 24 attribute_30 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 25 attribute_31 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 26 attribute_32 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 27 attribute_33 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 28 attribute_34 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 29 attribute_35 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 30 attribute_36 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 31 attribute_37 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 32 attribute_38 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 33 attribute_39 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 34 attribute_4 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 35 attribute_40 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 36 attribute_41 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 37 attribute_42 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 38 attribute_43 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 39 attribute_44 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 40 attribute_45 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 41 attribute_46 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 42 attribute_47 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 43 attribute_48 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 44 attribute_49 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 45 attribute_5 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 46 attribute_50 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 47 attribute_51 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 48 attribute_52 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 49 attribute_53 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 50 attribute_54 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 51 attribute_55 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 52 attribute_56 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 53 attribute_57 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 54 attribute_58 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 55 attribute_59 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 56 attribute_6 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 57 attribute_60 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 58 attribute_7 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 59 attribute_8 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 60 attribute_9 attribute real
    Jul 7, 2016 10:39:36 PM INFO: 61 class label nominal
    Hello
    I know what roles are but I wasn't aware of the specific addition of an R variable that describes it.
    Andrew
    Accepted Answer
    If you add a line like this near the beginning of the code, it seems to fix the issue.
    dat <- as.data.frame(dat)
    It's something to do with the type of the dat variable. In pure R, it's a data.frame. In RapidMiner it's also a data.table
    Andrew
    jujuUser: "juju"
    OP
    Hi Andrew,
    You solution fixed the problem. And I reproduced the mistake by doing dat = data.table(dat) in Rstudio.
    Thank you so much!
    User: "bhupendra_patil"
    just commenting for future users to be aware of
    Rapidminer Execute operator uses the data.table object vs data.frame
    so in the function rm_main(data1,data2,data3) all of data1,data2,data3 objects are datatables and not dataframes.
    So your best bet is converting the table to frame if you are more comfortable with dataframes
