Hi guys,
I'm trying to run RM processes through command.
I have a bat file and a exe file (under c:\....\scripts), and a process (properties file and rmp file).
How should I run the process?
Best regards,
Snir.
Hi snir,
this feature is only available if you also bought a RapidMiner Deployment server. If you did, you should be able to run
rapidminer -f myfile.xml
on linux. I guess on windows you use the bat? You can just give it a try. I am not sure if this also works for the rmp file.
Best,
Martin
Hi snir,
Best,
Martin
