Infrared spectrum data treatment before processing
Dears, we have been working with unscrambler for IR spectra (where we preteat the spectra with first and second derivatives and smoothing before doing anything else with the data... is there a way do to the same with RM?
Here is a picture of what I would like to do (go from A to C and then start the DM
And... at unscrambler I normally don't discretize the label column, use the numeric values. At RM only working nice creating cathegories (low, medium, high), which is fine too, but... wonder if I could do it the otherwise around too, or is this computationally too intensive.
1 - 4 of
41
sorry i am unsure what you want to do. Simply the conversion A->C or some data mining on C?
~Martin
