"R text/regression output results"
I've managed to get the R script working and displaying data frame numeric output in the Results section. My question is, it is possible to view R text output, such as regression results, or do I need to run a RapidMiner regression process in order to see the underlying estimated regression? Specifically, if I use the R lm command to generate the regression equation and then the summary(dependent variable) command, where does the summary output go? Thanks.
1 - 9 of
91
You have to explicitly use a print() command in your R script to print the summary to the Log window in RapidMiner.
If you want to capture and store your results, you have to take the single values of the summary (which is a list type in R) and extract and store them in a data table. If you do so, you could return them as an example set to RapidMiner.
Regards,
David
Regards,
David
Hi,
A couple of questions:
The R Edit Parameter Text: script editor is rather basic, is it possibler to replace it with an alternative/link to an alternative, for example, Notepad++?
Also, I take it that any variables generated in the R script are not available to access directly by Rapidminer, as they are no longer generated by the interactive console, as was the case previously? I guess my question is, how do I get variables from the R script into Rapidminer? Thanks.
i never used the R extension myself. But it should be visible in the Log window. I would highly recommend to use the new R scripting extension.
Cheers,
Martin
