🎉Community Raffle - Win $25
Join and Win
"[Solved] Missing values: The example set has no examples"
User: "w_fahey"
New Altair Community Member
Updated by Jocelyn
Hi
I have a simple process where I am trying to replace the missing values in a dataset using k-NN. When I connect my dataset to the "Impute Missing Values" Operator I get the error message "The example set has no examples"
The code is too large to paste here as there are about 300 variables.
Any help much appreciated
1 - 4 of 41
    User: "sgenzer"
    Altair Employee
    I assume you are trying to impute missing values before k-NN?
    User: "w_fahey"
    OP
    Hi Scott,
    The Impute missing values operator is nested. Inside this operator is the K-NN operator. Retreiving the dataset (an excel file) and the Impute missing values are all that is in this workflow.
    Will
    User: "w_fahey"
    OP
    Hi - I have sorted this out. There were columns in the dataset which had no values at all which, upon refection, it was unreasonable of me to expect K-NN to fill in the values.
    Thank you for your help regardless
    User: "sgenzer"
    Altair Employee
    ah good.  Glad you got it to work!
    Scott
