🎉Community Raffle - Win $25
Join and Win
Radoop training capabilities
User: "calippo"
New Altair Community Member
Updated by Jocelyn
I am waiting for a radoop license and I would like to fully understand its capabilities wrt spark integration.
I know that it allows to train spark models train predictive models in parallel...
What about other rapidminer algorithms? is possible to map a general classifier on a spark cluster and reduce the result using baggin/dagging or whatever?
1 - 2 of 21
    Hi,
    it is not yet possible to run a usual Rapidminer learner on different nodes. For a lot of algorithms it is simply not possible to be trained in a distributed fashion. If you have a radoop licence you get new additional operators for the spark algorithms which can be used.
    However - what is possible is ofc to apply a rapidminer model on hadoop. So you can learn on a sampled data set in memory and apply it in hadoop.
    Cheers,
    Martin
    User: "calippo"
    OP
    Ok, great
    that perfectly anwsers my question, thanks for quick anwser
