Issue with Nominal to Binominal
Hello
I am a new user to Rapid Miner, still trying to find my way around.
In a model I'm building, I keep coming across this error and can't find my way around it for hours now.
The error is when I try converting a 'nominal to binominal'.
The error I'm getting is 'Attribute filter does not match any attributes' when I try convert 'nominal to binomial' on the attribute named 'location3'
However, I have a break point in the prior step in model and it shows that it is successfully outputting the attribute named 'location3'
Any ideas?
Thanks in advance.
Here is my XML:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="6.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
<parameter key="resultfile" value="/Users/ml/Documents/Development/Social Data/tourism/validation-location-select.res"/>
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="6.4.000" expanded="true" height="60" name="Read CSV" width="90" x="45" y="75">
<parameter key="csv_file" value="/Users/ml/Documents/Development/Social Data/tourism/training locaton data for melb.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="encoding" value="UTF-8"/>
<list key="data_set_meta_data_information">
<parameter key="0" value="id.true.integer.attribute"/>
<parameter key="1" value="twitter_id.true.real.attribute"/>
<parameter key="2" value="location(2).true.text.attribute"/>
<parameter key="3" value="locatoin3.true.nominal.attribute"/>
<parameter key="4" value="tourist.true.nominal.label"/>
</list>
</operator>
<operator activated="true" class="set_role" compatibility="6.4.000" expanded="true" height="76" name="Set Role" width="90" x="179" y="75">
<parameter key="attribute_name" value="id"/>
<parameter key="target_role" value="id"/>
<list key="set_additional_roles"/>
</operator>
<operator activated="true" class="text:process_document_from_data" compatibility="6.1.000" expanded="true" height="76" name="Process Documents from Data" width="90" x="313" y="75">
<parameter key="keep_text" value="true"/>
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="999999"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="6.1.000" expanded="true" height="60" name="Tokenize" width="90" x="112" y="75"/>
<operator activated="true" class="text:transform_cases" compatibility="6.1.000" expanded="true" height="60" name="Transform Cases" width="90" x="246" y="75"/>
<operator activated="true" class="text:filter_by_length" compatibility="6.1.000" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="447" y="75">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="200"/>
</operator>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="set_role" compatibility="6.4.000" expanded="true" height="76" name="Set Role (2)" width="90" x="447" y="75">
<parameter key="attribute_name" value="locatoin3"/>
<parameter key="target_role" value="label"/>
</operator>
<operator activated="true" class="x_validation" compatibility="6.4.000" expanded="true" height="130" name="Validation" width="90" x="447" y="210">
<parameter key="number_of_validations" value="5"/>
<parameter key="sampling_type" value="stratified sampling"/>
<operator activated="true" breakpoints="after" class="select_attributes" compatibility="6.4.000" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="75">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="locatoin3"/>
<parameter key="attributes" value="locatoin3|tourist"/>
</operator>
<operator activated="true" class="nominal_to_binominal" compatibility="6.4.000" expanded="true" height="94" name="Nominal to Binominal" width="90" x="45" y="210">
<parameter key="transform_binominal" value="true"/>
</operator>
<operator activated="true" class="support_vector_machine_linear" compatibility="6.4.000" expanded="true" height="76" name="SVM (Linear)" width="90" x="179" y="435"/>
<connect from_port="training" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/>
<connect from_op="Nominal to Binominal" from_port="example set output" to_op="SVM (Linear)" to_port="training set"/>
<connect from_op="SVM (Linear)" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="6.4.000" expanded="true" height="76" name="Apply Model" width="90" x="45" y="120">
</operator>
<operator activated="true" class="performance" compatibility="6.4.000" expanded="true" height="76" name="Performance" width="90" x="179" y="210"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
<portSpacing port="sink_averagable 3" spacing="0"/>
</process>
</operator>
<connect from_op="Read CSV" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 2"/>
<connect from_op="Validation" from_port="training" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 3"/>
<connect from_op="Validation" from_port="averagable 2" to_port="result 4"/>
<portSpacing port="sink_result 3" spacing="0"/>
<portSpacing port="sink_result 4" spacing="0"/>
<portSpacing port="sink_result 5" spacing="0"/>
</process>
</operator>
</process>
Any ideas?
Thanks in advance.
Here is my XML:
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</list>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
</operator>
</process>
</operator>
</process>
1 - 10 of
101
Hello
Execution order seems to be correct, can you tell from the XML I posted?
I basically tried replicating the process contained here:
http://vancouverdata.blogspot.com.au/2010/11/text-analytics-with-rapidminer-part-5.html
All the functions are in similar order
Hi Martin,
Thanks for your help. I ticked 'special attribute' and it seemed the 'fix' my problem somewhat.
However, now I am getting another problem: now the data (attribute name: 'tourism', role:label) doesn't seem to be outputting from the nominal to binominal function.
In other words, nominal data is going in for this attribute, but no data is coming out for this attribute.
Any ideas?
Thanks again.
matt
See XML below:
<parameter key="attribute" value="tourist"/>
<parameter key="include_special_attributes" value="true"/>
</operator>
Any ideas?
Thanks again.
matt
See XML below:
</operator>
have you checked that the type of location3 is really binominal?
Cheers,
Martin
