Issue with Nominal to Binominal
User: "mattwl"
New Altair Community Member
Updated by Jocelyn
Hello
I am a new user to Rapid Miner, still trying to find my way around.
In a model I'm building, I keep coming across this error and can't find my way around it for hours now.
The error is when I try converting a 'nominal to binominal'.
The error I'm getting is 'Attribute filter does not match any attributes' when I try convert 'nominal to binomial' on the attribute named 'location3'
However, I have a break point in the prior step in model and it shows that it is successfully outputting the attribute named 'location3'
Any ideas?
Thanks in advance.
Here is my XML:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="6.4.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
    <parameter key="resultfile" value="/Users/ml/Documents/Development/Social Data/tourism/validation-location-select.res"/>
    <process expanded="true">
      <operator activated="true" class="read_csv" compatibility="6.4.000" expanded="true" height="60" name="Read CSV" width="90" x="45" y="75">
        <parameter key="csv_file" value="/Users/ml/Documents/Development/Social Data/tourism/training locaton data for melb.csv"/>
        <parameter key="column_separators" value=","/>
        <parameter key="first_row_as_names" value="false"/>
        <list key="annotations">
          <parameter key="0" value="Name"/>
        </list>
        <parameter key="encoding" value="UTF-8"/>
        <list key="data_set_meta_data_information">
          <parameter key="0" value="id.true.integer.attribute"/>
          <parameter key="1" value="twitter_id.true.real.attribute"/>
          <parameter key="2" value="location(2).true.text.attribute"/>
          <parameter key="3" value="locatoin3.true.nominal.attribute"/>
          <parameter key="4" value="tourist.true.nominal.label"/>
        </list>
      </operator>
      <operator activated="true" class="set_role" compatibility="6.4.000" expanded="true" height="76" name="Set Role" width="90" x="179" y="75">
        <parameter key="attribute_name" value="id"/>
        <parameter key="target_role" value="id"/>
        <list key="set_additional_roles"/>
      </operator>
      <operator activated="true" class="text:process_document_from_data" compatibility="6.1.000" expanded="true" height="76" name="Process Documents from Data" width="90" x="313" y="75">
        <parameter key="keep_text" value="true"/>
        <parameter key="prune_below_absolute" value="2"/>
        <parameter key="prune_above_absolute" value="999999"/>
        <list key="specify_weights"/>
          <operator activated="true" class="text:tokenize" compatibility="6.1.000" expanded="true" height="60" name="Tokenize" width="90" x="112" y="75"/>
          <operator activated="true" class="text:transform_cases" compatibility="6.1.000" expanded="true" height="60" name="Transform Cases" width="90" x="246" y="75"/>
          <operator activated="true" class="text:filter_by_length" compatibility="6.1.000" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="447" y="75">
            <parameter key="min_chars" value="2"/>
            <parameter key="max_chars" value="200"/>
          </operator>
          <connect from_port="document" to_op="Tokenize" to_port="document"/>
          <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
          <connect from_op="Transform Cases" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
          <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
          <portSpacing port="source_document" spacing="0"/>
          <portSpacing port="sink_document 1" spacing="0"/>
          <portSpacing port="sink_document 2" spacing="0"/>
        </process>
      </operator>
      <operator activated="true" class="set_role" compatibility="6.4.000" expanded="true" height="76" name="Set Role (2)" width="90" x="447" y="75">
        <parameter key="attribute_name" value="locatoin3"/>
        <parameter key="target_role" value="label"/>
      </operator>
      <operator activated="true" class="x_validation" compatibility="6.4.000" expanded="true" height="130" name="Validation" width="90" x="447" y="210">
        <parameter key="number_of_validations" value="5"/>
        <parameter key="sampling_type" value="stratified sampling"/>
          <operator activated="true" breakpoints="after" class="select_attributes" compatibility="6.4.000" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="75">
            <parameter key="attribute_filter_type" value="single"/>
            <parameter key="attribute" value="locatoin3"/>
            <parameter key="attributes" value="locatoin3|tourist"/>
          </operator>
          <operator activated="true" class="nominal_to_binominal" compatibility="6.4.000" expanded="true" height="94" name="Nominal to Binominal" width="90" x="45" y="210">
            <parameter key="transform_binominal" value="true"/>
          </operator>
          <operator activated="true" class="support_vector_machine_linear" compatibility="6.4.000" expanded="true" height="76" name="SVM (Linear)" width="90" x="179" y="435"/>
          <connect from_port="training" to_op="Select Attributes" to_port="example set input"/>
          <connect from_op="Select Attributes" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/>
          <connect from_op="Nominal to Binominal" from_port="example set output" to_op="SVM (Linear)" to_port="training set"/>
          <connect from_op="SVM (Linear)" from_port="model" to_port="model"/>
          <portSpacing port="source_training" spacing="0"/>
          <portSpacing port="sink_model" spacing="0"/>
          <portSpacing port="sink_through 1" spacing="0"/>
        </process>
          <operator activated="true" class="apply_model" compatibility="6.4.000" expanded="true" height="76" name="Apply Model" width="90" x="45" y="120">
          </operator>
          <operator activated="true" class="performance" compatibility="6.4.000" expanded="true" height="76" name="Performance" width="90" x="179" y="210"/>
          <connect from_port="model" to_op="Apply Model" to_port="model"/>
          <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
          <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
          <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
          <portSpacing port="source_model" spacing="0"/>
          <portSpacing port="source_test set" spacing="0"/>
          <portSpacing port="source_through 1" spacing="0"/>
          <portSpacing port="sink_averagable 1" spacing="0"/>
          <portSpacing port="sink_averagable 2" spacing="0"/>
          <portSpacing port="sink_averagable 3" spacing="0"/>
        </process>
      </operator>
      <connect from_op="Read CSV" from_port="output" to_op="Set Role" to_port="example set input"/>
      <connect from_op="Set Role" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
      <connect from_op="Process Documents from Data" from_port="example set" to_op="Set Role (2)" to_port="example set input"/>
      <connect from_op="Set Role (2)" from_port="example set output" to_op="Validation" to_port="training"/>
      <connect from_op="Validation" from_port="model" to_port="result 2"/>
      <connect from_op="Validation" from_port="training" to_port="result 1"/>
      <connect from_op="Validation" from_port="averagable 1" to_port="result 3"/>
      <connect from_op="Validation" from_port="averagable 2" to_port="result 4"/>
      <portSpacing port="sink_result 3" spacing="0"/>
      <portSpacing port="sink_result 4" spacing="0"/>
      <portSpacing port="sink_result 5" spacing="0"/>
    </process>
  </operator>
</process>
