🎉Community Raffle - Win $25
Join and Win
Retrieve from hive
User: "DocMusher"
New Altair Community Member
Updated by Jocelyn
Hi,
Where can I find some extra information on the WHERE clause in the retrieve from hive?
Cheers
Sven
1 - 2 of 21
    User: "DocMusher"
    OP
    Hi,
    The problem is similar to a previous problem of Java Focus except I have not process and xml open simultaneously, however, changes of table can be made in xml, if I change in the GUI, no change in xml code.
    Strange?
    Sven
    User: "DocMusher"
    OP
    Hi,
    The problem is that is the moment I change a to another table, which is a list coming from retrieve from hive, I can choose one, but it is not captured as such, no change in xml, and enter after changing is not altering my problem.
    If I change the value in xml, it is forwarded to the GUI.
    Working with macOS Yosemite and RM 6.4.
    Cheers
    Sven
