🎉Community Raffle - Win $25
Join and Win
date to str problem
User: "blatoo"
New Altair Community Member
Updated by Jocelyn
Hello all,
I have a problem with "date_str()", and I can not find more detailed description and example about it.
In the help:
Date to String (date_str(date1, DATE_FORMAT_CONSTANT, DATE_SHOW_CONSTANT)): Changes a date to a string using the specified format; example: date_str(A, DATE_FULL, DATE_SHOW_DATE_AND_TIME)
My Question is:
1. Where can I find the values of DATE_FORMAT_CONSTANT and DATE_SHOW_CONSTANT?
2. If I want turn "Jul 08, 2012" to "2012-07-08", how can I set the right parameter?
Thanks very much for the concentration!
1 - 1 of 11
    Hi there!
    date_str is to convert a date into a string. You want to do it vice verse. Thus date
    date_parse_custom(DateAtt,"MMM dd, yyyy")
    For the formatting i recommend http://docs.oracle.com/javase/7/docs/api/java/text/SimpleDateFormat.html . I always get confused by M and m. attached is an example process.
    Cheers,
    Martin
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="6.4.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30">
            <list key="attribute_values">
              <parameter key="DateAtt" value="&quot;Jul 08, 2012&quot;"/>
            </list>
            <list key="set_additional_roles"/>
          </operator>
          <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="30">
            <list key="function_descriptions">
              <parameter key="NewDateAtt" value="date_parse_custom(DateAtt,&quot;MMM dd, yyyy&quot;)"/>
            </list>
          </operator>
          <connect from_op="Generate Data by User Specification" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
