date_parse_custom(DateAtt,"MMM dd, yyyy")
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30"> <list key="attribute_values"> <parameter key="DateAtt" value=""Jul 08, 2012""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="30"> <list key="function_descriptions"> <parameter key="NewDateAtt" value="date_parse_custom(DateAtt,"MMM dd, yyyy")"/> </list> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
