🎉Community Raffle - Win $25
Join and Win
[SOLVED] problem in results perspective
User: "sukh"
New Altair Community Member
Updated by Jocelyn
Respected Sir,
my process was working well with rapid miner.
now its results perspective is not working due to which i am unable to see my results, although the process is working well as text file is written at the end consists of all the iterations of SVM.
Is it the problem of crash in rapid miner?
there is  no problem in working of process.only i could not get the example set in results perspective.
Kindly help me to solve the above mentioned problem.
Thanks and Regards:
Sukh
1 - 2 of 21
    User: "Marco_Boeck"
    Hi,
    I'm not sure I understand the problem correctly, but can you try the following while your are in the Results perspective:
    - click on "View" at the top menu bar
    - then click on "Restore Default Perspective"
    Does it fix your problem?
    Regards,
    Marco
    User: "sukh"
    OP
    Thanks sir,
    it works. but it gave me the same problem many times a day.
    Regards:
    sukh
