🎉Community Raffle - Win $25
Join and Win
How To Call Rapidminer Process In Eclipse
ShivangiUser: "Shivangi"
New Altair Community Member
Updated by Jocelyn
I am MCA 5th sem student and doing my project
i connect rapidminer with eclipse so can you help me for how to call rapidminer processes into eclipse
1 - 10 of 101
    Hi,
    please have a look at the development FAQ: http://rapid-i.com/rapidforum/index.php/topic,5807.0.html
    Regards,
    Marco
    Thank You Sir For Replaying
    Bt sir i did't get it  ,can you  give me specific example ? :(
    Hi,
    please be a bit more specific. The FAQ contains information and examples from making Studio available in Eclipse (and your project) to executing processes and inspecting the results.
    What exactly is it you're having problems with?
    Regards,
    Marco
    Sir, i tried following code for calling replace missing operator of rapid miner from the eclipse Juno......
    import com.rapidminer.RapidMiner;
    import com.rapidminer.Process;
    import com.rapidminer.example.Attribute;
    import com.rapidminer.example.Example;
    import com.rapidminer.example.ExampleSet;
    import com.rapidminer.operator.IOContainer;
    import com.rapidminer.operator.IOObject;
    import com.rapidminer.operator.Operator;
    import com.rapidminer.operator.OperatorException;
    import java.io.File;
    import java.io.IOException;
    import java.util.Iterator;
    import org.freehep.graphicsio.swf.DefineBits;
    import com.rapidminer.operator.io.ExcelExampleSource;
    import com.rapidminer.repository.IOObjectEntry;
    import com.rapidminer.repository.ProcessEntry;
    import com.rapidminer.repository.RepositoryLocation;
    import com.rapidminer.tools.XMLException;
    public class listattribute {
        public static void main(String args[]) throws Exception {
        // this initializes RapidMiner with your repositories available
        RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
        RapidMiner.init();
        // loads the process from the repository
        Process location = new Process(new File("C:\\Users\\Dimpal\\.RapidMiner5\\repositories\\Local Repository\\processes\\test.rmp"));
        //Entry entry = location.locateEntry();
        //if (entry instanceof ProcessEntry) {
            //Process process = new RepositoryProcessLocation(location).load(null);
      Operator op = location.getOperator("Read Excel");
      op.setParameter(ExcelExampleSource.PARAMETER_EXCEL_FILE, "C:\\Users\\Dimpal\\.RapidMiner5\\repositories\\Local Repository\\processes\\sample.xlsx");
      Operator op1=location.getOperator("Replace Missing Values");
      op1.setParameter("attribute","city");
      op1.setParameter("default", "average");
      //op1.setParameter("replenishment Value","Y");
        Operator outp = location.getOperator("Write Excel");
      outp.setParameter(ExcelExampleSource.PARAMETER_EXCEL_FILE, "C:\\Users\\Dimpal\\.RapidMiner5\\repositories\\Local Repository\\processes\\data2.xlsx");
      //RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
      // RapidMiner.init();
      // Process location1 = new Process(new File("D:\\rm\\replacemiss.rmp"));
      // Operator opa = location.getOperator("Read Excel");
      //opa.setParameter(ExcelExampleSource.PARAMETER_EXCEL_FILE, "D:\\rm\\data2.xlsx");
      // Operator opa1=location.getOperator("Replace Missing Values");
      // opa1.setParameter("attribute","");
      // opa1.setParameter("default", "average");
        IOContainer ioResult = location.run();
            IOObject result = ioResult.getElementAt(0);
        // use the result(s) as needed, for example if your process just returns one ExampleSet, use this:
        if (ioResult.getElementAt(0) instanceof ExampleSet) {
            ExampleSet resultSet = (ExampleSet)ioResult.getElementAt(0);
            System.out.println(result);
            int i=0;
            for (Example example : resultSet) {
                Iterator<Attribute> allAtts = example.getAttributes().allAttributes();
                while(allAtts.hasNext()) {
                    Attribute a = allAtts.next();
                  if(i<=3)
                    System.out.print(a.getName()+ "  ");
                    i++;
            System.out.println("\n");
                        if (a.isNumerical()) {
                                double value = example.getValue(a);
                                System.out.print(value+ " " );
                                //System.out.println("\n");
                        } else {
                                String value = example.getValueAsString(a);
                                System.out.print(value+ " ");
    And i got the Following exception ...
    Apr 30, 2015 6:55:07 PM com.rapidminer.RapidMiner performFirstInitialization
    INFO: Performing upgrade  from version 5.3.013 to version 5.3.015
    Apr 30, 2015 6:55:08 PM com.rapidminer.tools.ParameterService init
    INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
    Apr 30, 2015 6:55:08 PM com.rapidminer.tools.I18N <clinit>
    INFO: Set locale to en.
    Apr 30, 2015 6:55:09 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
    INFO: Property rapidminer.home is not set. Guessing.
    INFO: Trying base directory of classes (build) 'D:\SHIVU\Project\Git'...gotcha!
    Apr 30, 2015 6:55:26 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
    INFO: Default version of expression parser registered successfully
    Apr 30, 2015 6:55:30 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
    WARNING: Password in XML file looks like unencrypted plain text.
    Apr 30, 2015 6:55:39 PM com.rapidminer.tools.OperatorService init
    INFO: Number of registered operator classes: 443; number of registered operator descriptions: 444; number of replacements: 403
    Apr 30, 2015 6:55:40 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
    WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
    Apr 30, 2015 6:55:40 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
    INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
    INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed.
    Exception in thread "main" java.lang.NullPointerException
    at listattribute.main(listattribute.java:44)
    Hi,
    you're trying to access an operator which cannot be found under the specified name it seems. Debug your process and see what operators it contains and how they are called. Probably you misspelled its name.
    Regards,
    Marco
    Thank you sir
    Sir i also try for clustering but i  got same NullPointerException.
    For calling rapidminer process in eclipse XML file is required??
    Hi,
    to create a simply process, all you really need is a String which equals the contents of a .rmp file in your repository, aka a process. The content is XML, but you don't need any files for that.
    Regards,
    Marco
    OP
    Hello
    Sir .rmp file is ok but i get nullpointerexception with following line:
    please reply me
    Hi,
    you can use your regular debugging tools for figuring out what's wrong. It's Java, after all :)
    As I already said, in that line you can only get an NPE if the operator you retrieved was null. And that is the case when you try to get an Operator from a Process via a non-existent name.
    Regards,
    Marco
    hello  sir
    about the page which  explain how to  call  rapid miner  process in eclipse  it doesnt working
      can you help  me please
