[SOLVED] Saved Process fails if it has an Octave Script Operator
Hello,
I recently upgraded to Rapidminer 6.3 and I experienced a problem with the Octave Script Operator. I noticed that if I save a process containing such operator the process fails to execute again as long as the operator is present. If I remove the operator the process runs again. The process did not fail until I saved it. I tried also to run processes created with Rapidminer 5.3, which I also have installed, with the same result. However processes created with both versions run without any problem in Rapidminer 5.3.
I have octminer version 2.2.003.
I submitted the report to the bug-tracker here:
http://bugs.rapid-i.com/show_bug.cgi?id=1854
I hope you can help me. I thank you in advance for your time.
Best regards,
Germán.
Best regards,
Germán.
1 - 6 of
61
Hi Marco,
thank you very much for your answer. I posted my problem at the issue mailing list of the octminer project as I couldn't find another way to contact the extension authors.
I briefly worked with Rapidminer 6.0 before upgrading to 6.3 and I don't remember having experienced this problem.
Could you please tell me in which version the class com/rapid_i/Launcher was removed?
Do I have a way to revert to Rapidminer 6.0 or do I need to keep working with the 5.3 version?
I looked for a 6.0 installer but I couldn't find any.
Best regards,
Germán.
Best regards,
Germán.
Hi,
looking at the source code, it looks like it should suffice to replace
The launcher class currently used was removed with either Studio 6.1 or 6.2 if I'm not mistaken.
Regards,
Marco
with
URL url = Launcher.class.getClassLoader().getResource(".");
That would probably be compatible for all previous and future Studio versions.
URL url = Operator.class.getClassLoader().getResource(".");
Regards,
Marco
the Octave Script Operator is part of a 3rd party extension which is not maintained by RapidMiner. Looking at the stacktrace, it looks like it is compiled against outdated code. The called class "com/rapid_i/Launcher" does no longer exist. Please have a look at the extension site on the marketplace and contact the author: http://marketplace.rapid-i.com/UpdateServer/faces/product_details.xhtml?productId=rmx_octave
Regards,
Marco
